R33 Parts
Got a few left over parts from my r33 part out, priced to clear.
ISC rear camber arms, $50
ISC Rear traction arms $50
Locked Turbo R33 diff $200
044 Fuel pump with surge tank and proflow fittings $200
Whiteline rear sway bar $100
Straight thru 3" exhaust with trust PE2 cannon $150
Front R33 calipers $250
Rear R33 calipers $150
Rear cradle minus arms, diff and calipers $150
R33 manual tailshaft $50
Located Northern suburbs melbourne. Phill - 0421986981
https://www.sau.com.au/forums/topic/471351-r33-parts-ssr-hasemi-wheels/
Genuine 2 piece Hasemi Sport Prot S Type R by SSR
Centre pieces just got powder coated black and the hoops got repolished. Every rim bolt got polished also. Comes with angled stainless steel valve stems with crome caps. 17 x 9 +20 offset all round 5 x 114.3 stud pattern $1800 neg. Located Northern Suburbs Melbourne. Contact Anth 0421 757 329.
14469599_10157431209655176_4806394494466
14494839_10157431209670176_5489165851449
14449923_10157431209650176_2878900956929
14470492_10157431209665176_5057380291484
14469571_10157431209675176_5319893857028
Stock R33 GTST turbo with manifold
Got an R33 gtst turbo and manifold for sale. $200 non negotiable. Good working order. Located Thomastown 0421 986 981
  • 1 month later...
  • 1 month later...
R33 Parts
  • 4 weeks later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
