Josh's Garage Clean Out - Injectors, Turbo, ECU and More
Hey guys. Reached a stage where I can finally clear out a bunch of stuff I've accumulated during my build. Prices listed are ONO, available for pickup from Auburn NSW 2144. Willing to ship at buyer's expense. Parts are also listed elsewhere.
Too many pictures so I've created a Google Drive link here: https://drive.google.com/drive/folders/0BxkDOGQ7as9eLTE2RDE5RDVFRm8?usp=sharing
Stock RB25DET Turbo, worked fine when pulled off for upgrade: $140
"MaxSpeedingRods" Ebay Special Turbo - Decided to go a different way. Brand new, never used. Specs on request: $250
NISTUNE Z32 ECU to suit RB25DET - removed for upgrade: $400
Stock RB25DET ECU from R33 S2 Manual: $80
Stock RB25DET S2 AFM: $50
GFB G-Force II Boost Controller - fitted for test, used something else, brand new as pictured: $240
550cc WRX STI Injectors with adapters to suit RB25: $200
370cc OEM RB25DET Injectors: $150
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $180
JVC KW-R500 Double Din Head Unit/Car Stereo, works fine and comes with harnesses: $60
Alpine MRX-F35 4 Channel Amp - Works fine: $150
Update:
Update:
  • 3 weeks later...
On 01/08/2017 at 7:12 PM, inmaniac said:
Update:
Yellow Jacket Coil Packs - Used for 400km: $250
Updated. Now also have a full set of YJ's to suit S2 RB25, $250 ono
  • 4 weeks later...
  • 1 month later...
"MaxSpeedingRods" Ebay Special Turbo: $200
550cc ebay jecs Injectors with adapters to suit RB25: $100
370cc OEM RB25DET Injectors: $120
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $120
JVC KW-R500 Double Din Head Unit/Car Stereo, works fine and comes with harnesses: $40
Update - now priced to go go go
Also got my staggered set of VOLK TE37's here:
  • 4 months later...
UPDATE:
Seriously priced to go.
"MaxSpeedingRods" Ebay Special Turbo BRAND NEW IN BOX: $150
Yellow Jacket Coil Packs - Used for 400km: $200
Stock RB25DET ECU from R33 S2 Manual: $50
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $100
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
