Will a Z32 CAS work on an R32 GT-R?
Hey guys,
I am having some issues which I have narrowed down to what (I believe) is the CAS but part availability is a bit of a bitch here in the states.  An RB26 series 1 CAS is going to run between $500-$600 with shipping.  There is a company here that sells rebuilds but they are out of stock with no anticipated date for getting inventory in.  I was wondering if a Z32 CAS ($140) would work in its place?
I have searched around on this and I have found some conflicting information and wanted to know if anyone here has tried this.  I saw one person claim to use one on an RB swap into a 240.  Some posts say the plug needs rewired, some allude to some internal adjustments to compensate for the trigger wheel being 120 degrees off.  I am not oppsed to cracking open the CAS to modify it to work but I don't want to waste my time if it's a non-starter.
The car was delivered to me back in February in partially running condition.  It would miss sporadically at partial throttle and would die out the moment I let off the gas.  Since then the car has stopped running altogether.  The last time I took it around the block to test a repair it was extremely hard to get restarted and keep running.  I limped it into the garage and it has been sitting there since.  The car will turn over and occasionally sounds like it wants to start but never does.  Sometimes I get a backfire.  The only code the car was throwing was for "ignition", I think it was a 12 but it has been a few months.
Work done so far:
Opened both MAF's to check for loose solders (all connections were good), cleaned both MAF's
Cleaned air filters (Mine's intake with K&N's)
New NGK BCPR7EIX Iridium plugs (it had some ngk race plugs installed when it arrived)
New battery
New coil packs
New coil pack wiring harness
New fuel pump (aeromotive 340)
New fuel filter
New ignition module (the old one tested bad and I really hope this would solve the issue haha)
Tried to start the car with starter fluid (sprayed in behind one of the mafs to avoid messing it up)
Thanks in advance for any feedback, suggestions, or input,
Brock
https://www.sau.com.au/forums/topic/471493-will-a-z32-cas-work-on-an-r32-gt-r/
Thanks for the response Kiwi.  I can try to reach out to those sellers but I may run into issues getting the parts shipped internationally.  Sadly no one around here knows the first thing about Skylines so getting anything reconditioned would be a roll of the dice with a crazy premium added on.  If that were an option I would have had my current CAS refurbed already.  I have even considered pulling apart a Z32 CAS to see if I could use any of the pieces inside to refurb the unit myself.
I am still curious about the viability of the Z32 CAS as it would present a very cost effective and easy to source alternative to buying 25 year old used electronics and hoping they work.
Jealous of that Stagea btw, those things are sexy and we can't have them for another 5 years haha.
So the Trademe site is only open to residents of New Zealand and Australia and will not even let me register haha.  So it is back to the drawing board.  The Z32 and R32 CAS units are visually identical.  I feel like someone must have tried this at some point.  Maybe Skyline parts are just too easily found outside the USA!
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
