I'm looking for a cheap R33 GTS-T
all i want is it to be in good condition inside and out... mods aren't a big problem i'm looking to spend about $15,500...can it be done..does anyone know if that can be done
i would like a black manual apart from that stock is fine although any mods would be greatly appriciated...thanks and if anyone knows one for sale for this price in Vic please PM or e-mail me at [email protected]
https://www.sau.com.au/forums/topic/47172-cheap-r33-gts-t/
You could find an OK R33 GTS25t for around $15,00 but certainly not a good, clean example under $15,000. You should be prepared to pay a little more than $15,000 for a decent, clean example. Have a look at this decent R33 GTS25t 5 Speed Manual.
http://www.carsales.com.au/pls/carsales/!cs_content.private_vehicle?vehicle_id=128605&current_rec=66&total_rec=130&sort_type=&price_max=20000&make_id=5&model_id=73&state_id=-1&search_distance=25
Dallas
sock
https://www.sau.com.au/forums/topic/47172-cheap-r33-gts-t/#findComment-954008
yeah it's all about money problems lol i'm onna be buying it for my first car....any opinions on that :) i'd be interested to hear bout that lol anyway i'm just after a good clean car that runs well black and manual....any mods are great but not needed atm...thanks fo the input though...remember if u see one in vic please tell me
https://www.sau.com.au/forums/topic/47172-cheap-r33-gts-t/#findComment-954040
Maybe an older car such as a R32 for your first car because you must think of things such as parts and mantinence, and some R33's are comming up to their 100,000 KM service, timing belt etc arn't cheap. Also factor in insurance, insurance for young driver's with a Japanese Imported car, espicially a turbocharged one won't be cheap. Just a few things you should think of before going ahead and purchasing the car. :)
https://www.sau.com.au/forums/topic/47172-cheap-r33-gts-t/#findComment-954045
im in the exact same boat as you my friend. Looking to spend 15 at the most on a good car. I really have my eyes on an r33, but the reality is for a good example of one, u have to spend at least a few grand more, and thats with out factoring in insurance and all that other annoying shit. For 15 you would be best getting something like a r32, 180sx, s13, series 1-5 rx7, 89-90 supra, or maybe even an early model s14. ya never know though, someone might be wanting to offload their r33 cheap somewhere down the road........im still hoping for that to come along, haha. Luck and chance play a big role in the car market in my experience.
https://www.sau.com.au/forums/topic/47172-cheap-r33-gts-t/#findComment-954385
Difficult situation your in dude. I was in the same boat when I was 18.... Insurance was expensive and I couldnt afford much... I know you probably dont wanna hear this dude but if i were u, work your arse off for 6-12 months and get some more money in the bank account. if your looking at an r33 turbo manual for 15k you may get one but it will cost u a bit to get the little problems fixed eg(paint touch-ups, timing belts, detailed etc.) If you save a bit more and wait and spend around 18k-20k you will get a clean low kilometer 1995mdl with a set of wheels and maybe a bodykit.... Plus your insurance will come down because you are older... Its only 6-12 month wait and you will get a much better car with no ongoing problems.... Good luck champ!
https://www.sau.com.au/forums/topic/47172-cheap-r33-gts-t/#findComment-955369
i've seen a few that look in pretty good condition for about $15, 500-$16, 500 so i mite try n wait for one of them to pop up. how many kms should a 1993-1994 have on it if it's legit...i've read the guide to buying secondhand ones...excellent btw...but i'm not sure how to tell...also i'm not interested in one that has heaps of mods because i can't have it with to much more power Victorian P's :S:S anyway just want it to have good interior and exterior and no mechanical problems or things about to ware out eg timing belts tyres...anyone think it's stupid to give a turbo charged car to a 18 y/o ...benn driving since i was 7 or something ...but really driving since bout 14
https://www.sau.com.au/forums/topic/47172-cheap-r33-gts-t/#findComment-955696
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
