Help, What coilovers go on a 2000 r34 gt sedan?
Hey guys, im pretty new to the skyline crew, and to the SAU community ive just bought myself a 2000, r34 sedan N/A and i was wondering what coilovers would fit? I've done some research but not 100% percernt sure what will fit.
Help would be much appreciated :) Located QLD
Edited by Billy 34
All of them. Most popular atm seems to be MCA, could also go HSD/BC/Tein/ebayspec/pedders/bilsteins depends on your budget and application
Edit: MCA is from QLD, support the locals ;)
Have a look at your rear suspension. There are 2 types. Eyelet and fork. It should be pretty obvious what you have. (I'd be betting eyelet) in which case you would need R33 coilovers or ones that are specifically for the 25gt variant.
Yeah bro, but would they just be r34 gt sedans?
Yep, their the same as mine. R33 coilovers should bolt straight in. There mine be some differences on different coilovers. Just know to get to the top of the rears you need to remove the backseat. (At least on the coupe)
i have a sedan bro, would they be any 33 ones, because i heard i need 33 gtr coils to fit?
Edited by Billy 34
Just now, GTofuS-T said:
No, the GTR rear coilovers are the fork style same as R34 GT-T, the GT is eyelet as above which woudl be the same as R33 GTS-T (and GTS I would assume?)
alright mad, ill scout some out tonight, not sure if i should get someone to change them for me or if i should give it ago haha :) cheers for your help brother
3 hours ago, vxsr33 said:
Give it a go yourself and save your money. its very easy, will probs take about 3 or 4 hours if you haven't done it before.
I'll give it all, heard the spring are dangerous and can fling out if they aren't pulled out correctly
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
