  • Replies 82
Had a good time
First run on a 1/4 ever i got [email protected] 2.188 60ft!
Next few runs were bad 60ft times.. out of 8 runs only 2 were less than 2.3, not sure what i changed but it definately affected my 60ft. Worst 60ft was 2.508 which i got twice! Best et was 4th run i think, 13.878 @ 102.93 2.206 60ft. thought i had 13.7 :)
Good nite though, cant wait to give it another go, i was really suprised to see how much changing little things affects your times, i did a burnout and got a worse 60ft than i did before, upping boost made 60ft times worse, but more mid/top end. Guess the more playing around the better u get
I found an error on one of my time slips too, on the 13.9 run the other person got 14.599 and for margin it says 1.088 ?
2.998!
O M G ...
Ha! call that a 60ft time?? I've had a 6.59 you pussies :wassup:
Tonight my best were 2.097,2.082 and 2.029 got no top end though best I could do was 13.8 at 100.27mph and 13.9 at 104....good enough to win 5 out of 8 runs though 2 of the losses went to a 10.9 at 130mph and a 14.09 at 126mph.
Got myself a rotary too + Holden ute and a commidor
Fairly average night topped off by collecting a $150 fine ...89 in a 70 zone.
After cruising all the way home just under the limits I had a momentary lapse of attention.....at the end of the Centenary Hwy....of all places....it really pissed me off!!!
Nice to see you guys out there. knore seems to have got off to a good start :)
Addit: I got track slicks....but I got no squat
Nice to see you guys out there. knore seems to have got off to a good start  :D
Shyyt! I was lucky then, i was following MJ and the rest of the lines when i realised my bonnet was popped! so i pulled over closed it and made haste to catch up :Oops:
Hey matt, can u post up the details for that 14 flat run i did, i didnt end up collecting the time slip cause i went through the pile like 3 times and couldnt find it
Im still trying to figure out why nearly all my 60ft's were 2.4+, I wasnt getting wheelspin, the only thing i can think of on my 2 13 runs were i got to stage first and wasnt rushed, so i must have got the stall just right. I tried using the handbrake on one, but it broke traction when i released which gave me a 14.5
After last nite i kinda want a stall converter, cos i just couldnt stall high enough, on one of my races i was against a 180sx, he got a 12.88 with a 1.766 60ft!!
If we could get a 1.766 then imagine the ET ;)
Is your car an auto Knore?
Yes, thats where the problem is
Everything else is fine, i just cant load up enough power at the start
Im thinking about going on a full tank next time, so i can stall higher without the wheels spinning. Whats affecting my 60ft is that few seconds on 2.5L power (or lack of i should say) before the turbo hits. If i can cut that out, 2.0 60ft should be obtainable and good for some mid 13s
I tried stalling higher, but the wheels started spinning on the starting line :Oops:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
