Willowbank Wed 28th
51jay
 Share
  • Replies 82
Had a good time
First run on a 1/4 ever i got [email protected] 2.188 60ft!
Next few runs were bad 60ft times.. out of 8 runs only 2 were less than 2.3, not sure what i changed but it definately affected my 60ft. Worst 60ft was 2.508 which i got twice! Best et was 4th run i think, 13.878 @ 102.93 2.206 60ft. thought i had 13.7 :)
Good nite though, cant wait to give it another go, i was really suprised to see how much changing little things affects your times, i did a burnout and got a worse 60ft than i did before, upping boost made 60ft times worse, but more mid/top end. Guess the more playing around the better u get
I found an error on one of my time slips too, on the 13.9 run the other person got 14.599 and for margin it says 1.088 ?
2.998!
O M G ...
Ha! call that a 60ft time?? I've had a 6.59 you pussies :wassup:
Tonight my best were 2.097,2.082 and 2.029 got no top end though best I could do was 13.8 at 100.27mph and 13.9 at 104....good enough to win 5 out of 8 runs though 2 of the losses went to a 10.9 at 130mph and a 14.09 at 126mph.
Got myself a rotary too + Holden ute and a commidor
Fairly average night topped off by collecting a $150 fine ...89 in a 70 zone.
After cruising all the way home just under the limits I had a momentary lapse of attention.....at the end of the Centenary Hwy....of all places....it really pissed me off!!!
Nice to see you guys out there. knore seems to have got off to a good start :)
Addit: I got track slicks....but I got no squat
Nice to see you guys out there. knore seems to have got off to a good start  :D
Shyyt! I was lucky then, i was following MJ and the rest of the lines when i realised my bonnet was popped! so i pulled over closed it and made haste to catch up :Oops:
Hey matt, can u post up the details for that 14 flat run i did, i didnt end up collecting the time slip cause i went through the pile like 3 times and couldnt find it
Im still trying to figure out why nearly all my 60ft's were 2.4+, I wasnt getting wheelspin, the only thing i can think of on my 2 13 runs were i got to stage first and wasnt rushed, so i must have got the stall just right. I tried using the handbrake on one, but it broke traction when i released which gave me a 14.5
After last nite i kinda want a stall converter, cos i just couldnt stall high enough, on one of my races i was against a 180sx, he got a 12.88 with a 1.766 60ft!!
If we could get a 1.766 then imagine the ET ;)
Is your car an auto Knore?
Yes, thats where the problem is
Everything else is fine, i just cant load up enough power at the start
Im thinking about going on a full tank next time, so i can stall higher without the wheels spinning. Whats affecting my 60ft is that few seconds on 2.5L power (or lack of i should say) before the turbo hits. If i can cut that out, 2.0 60ft should be obtainable and good for some mid 13s
I tried stalling higher, but the wheels started spinning on the starting line :Oops:
yeh i noticed that knore...one stage you were sittin there and your back wheels were going very slowly around :rofl:
Slow motion burnout! I love it.:headspin:
 Share
    • They did get back to me. First response is from the mechanic that did the work. The problem is that the information that followed wasn't in the original report, which again, I let car inspect know should have been provided and influenced my decision to buy. Ball is back in their court and they have 5 more days to respond.  The actual structural damage was not a complete write off as they had me originally believe.  It just needed to be corrected properly and cleanly as opposed to the botch job of whoever did it last on the rad support and undercarriage. Smoothed out the scrappy welds and did it properly plus painted.
    • Haven't updated this is a while. -5 speed conversion is done. Then center console, parking brake handle, and mounting bracket can be adapted from a R34 since the S2 parts are all disco. Console is a slightly different grain pattern and color but works fine. R33/ R34 GTS (no booster) clutch pedal works as well as the matching master cylinder. Wiring is simple, jump the starter connector at the fuse box, note which wires are connected at which position on the auto neutral safety switch and cut off the switch harness and connect to the corresponding switch on the 5 speed. -Rear R34 rear subframe swap is completed. Full Nismo arm set, 2-way LSD set up soft, 322mm Brembo brakes, Ohlins Flag-R coil overs (need to drop the spring rate 1Kg) -RB swap is under way. HKS Step 2 High Response 2.8 BCD stroker kit / Step 2 V-Cam / GTIII 4R Kit I may not use the 4R kit but not sure yet as I've seen some pretty decent dyno sheets on it and it doesn't spool as slow as people think when you have v-cam. I have the wiring manual for the car and a spare 260RS harness so the wiring shouldn't be that bad but I just haven't had the time to invest in it. If anyone has a suggestion for someone who can handle it let me know! I have a bunch of spare 5mt swap parts and some Nismo 580 turbos if anyone needs/wants them hit me up. Located in California but willing to ship. As always, thanks to all the members who have answered my questions and helped this project keep moving!
    • Did Car Inspect get back to you? How bad was the actual "structural" damage? What front surgery was required?
    • I would be, however the last PS I owned was a PS1 and the last GT I played was GT1 lol. Also, how do you dads even have time to do anything? I barely have time to even sleep 7 hours a night!
    • I was thinking of setting up a multiplayer comp. Just a series that anybody could join and we could run a table here.  Anybody interested in that?
