Intermittent running problems
Hi everyone, should probably start this off with a bit of background info.
this is my back and fourth to work car, i do have a lead foot sometimes, but I don't need it for the power.
my r33 non turbo automatic with the RB25DE has been running rough intermittently
when it first started
I thought it might have  been a fuel issue, so changed the fuel filter, oil, oil filter  and blew out the air filter
i pulled the coil packs out and they were starting to show small problems
Problem continued
, had to wait a few days to fix that but finally got round to it, cleaned the carby and mass flow, the spark plugs i had thought should be still good since the last service not many k's before but a fair amount of time
it drove smooth the next day, then started to drive rough 30mins in the day after.
i pulled it apart again deciding to change the plugs, chucked carby cleaner
drove the next day calmly, day later ran rough 35mins into drive
decided the coolant temperature sensor needed to be replaced
drove to and from work smoothly
then jumped in to run down the road and it didn't just wait to be 10 or 15 mins into the drive, it ran rough all the way
https://www.sau.com.au/forums/topic/472027-intermittent-running-problems/
Needs twin carbs. What did you do about the coils? At a minimum they need to be thoroughly cleaned and then wrapped in insulating tape - better still replace with OEM or Splitfires only.
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
