M35 won't fire
Evening, sorry about the long post but I'm trying to give as much info as possible.
I have recently acquired a 2001 M35 stagea (VQ25DET), the morning after driving it home it it would turn over  but not fire, after 10 minutes of trying it finally fired up but ran like crap. Next few starts it started and ran well.
Saturday morning it started and drove fine. Come Saturday afternoon it wound over and over, after 20 minutes of trying it finally started, but ran terribly all the way home. Got it home and shut it off and tried to restart it and it just wouldn't fire. Sunday morning I tried and just keeps winding.
I have checked all the fuses, changed all the coils, the plugs, the immobiliser batteries and the CAS and it still won't fire, when turning over it will get the occasional cough but that's it. The cam sensors were changed with the recal but I'm not sure how long ago.
The car is running a Greddy Emanage and the MIL light is on all the time (owner said this and after searching it is a common thing with these ECU's)
I have tried the self diagnostic thing with the key and the pedal but for the life of me I can't get the MIL to flash, I've used a stop watch to time everything and still can't, no sure if just me or emanage has something to do with it
I don't have a scan tool and can't start the car to take it anywhere, does anyone have any ideas or suggestions on why it won't fire?
Edited by Coullsy
https://www.sau.com.au/forums/topic/472151-m35-wont-fire/
May be flooded. I would check to see if you have spark. If it does, dry the plugs and try some start ya bastard. Something obviously isn't right considering it runs well then it doesn't. Do you have the software for the emu so you can see what's going on? There was someone over in Adelaide that is pretty knowledgeable with m35 and emu. I think its BoostdR.
https://www.sau.com.au/forums/topic/472151-m35-wont-fire/#findComment-7851574
Ive attached a quick video of the spark, to me it looks weak, as I believe it's meant to be a bright blue, but that could be from the gal I had in the tester.
i did manage to finally get it to throw codes which came up with the following.
0100 - AFM
1320 - ignition signal
0110 - intake air temp sensor
1705 (I counted 1805, but could of counted wrong, will confirm)- Throttle position sensor circuit A/T
The 0100 AFM fault may be because I disconnected it and tried to start it to eliminate it. I will reset the codes and see what it throws up again.
Would the 0110 code be related to the above?
1320 code I don't know what it could be, as I've done the coils, plugs, CAS and rechecked all the plugs (possibly throwing the codes due to not resetting after changing them?)
Is it possible that the TPS is the issue that is preventing it from starting?
IMG_5996.MOV
https://www.sau.com.au/forums/topic/472151-m35-wont-fire/#findComment-7851631
  • 4 months later...
So an update on this for those interested.
Turns out that the Emanage was dumping alot of fuel into the cylinders.
instead of dealing with the emanage, it was ripped out and now i have installed a Haltech Elite 2500. The car is together and has been tuned. Currently making a healthy 252AWKW.
https://www.sau.com.au/forums/topic/472151-m35-wont-fire/#findComment-7867880
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
