TLDR hard or not hard?
Do you really want another turbo Nissan?
Part of the appeal of a 370 weekender is that it's NA and hopefully less shit to go wrong.
Says the man whoi looks at 435/M4 and the equivalent 5 series cars also...
Yeah OK, wonder if the next Z will get VR30DETT like the Inifniti Red Sport or similar?
Dont need 4 seats, don'texpect I'll do heaps of K's so service not an issue - depreciation will cost way more.
Pipe dream at the moment, need my shed done and the road up to my property sealed at minimum.
It's looking like it is, Nissan did a 370 demo car with one for sema
https://www.google.com/amp/s/www.motortrend.com/news/nissan-370z-project-clubsport-23-packs-twin-turbo-v-6-sema/amp/
If going to buy something get a demo or slightly used that was one of the things when I bought this as was a demo but was priced well and got it heaps cheap.
28 minutes ago, Dose Pipe Sutututu said:
Sshhh you, I've already got 3 turbo'd Nissans and they provide enough headaches.
Got the first layer of paint on the calipers, will let them dry for a day then apply new stickers and clear coat.
New coffee machine showed up too today. Got sick of plunger and espresso pot. Goes alright with week old grind will get a few different beans as got a few local roasters
  • Like 1
  • Haha 1
2 minutes ago, ActionDan said:
Incoming comment about how Dose could've had a BMW by now...
:rofl2::rofl2:
There's a 2018 M2 competition up here that was just traded....... Sure they would give top dollar for the skyline
Edited by robbo_rb180
On 6/30/2020 at 2:57 PM, Dose Pipe Sutututu said:
I see we have a few common interests @robbo_rb180
Turbo cars that never work, coffee machines
Definitely, pretty spoilt for a good choice of coffee roasters locally.
Spent a good part of the day in the shed getting fiddly jobs done to get the sil80 rolling. Had to sand the brake calipers as wasn't happy with the finish so a good sand and another coat of paint they came up a lot nicer so tomorrow will put on the new stickers and clear coat.
Made good progress welding in the braces. Did a lot of them with the tig but struggled doing a few small ones with the mig. Got 4 left to do on the cradle tomorrow before prep for paint.
IMG_20200702_095600.thumb.jpg.d7d8f4a658ba392a7c7d9147089e8d5a.jpgIMG_20200702_111351.thumb.jpg.204ec73000988303f2efc3ecdce198c0.jpgIMG_20200702_160857.thumb.jpg.521ec1b13388f8da8e7500f0a808fdd1.jpg
Odered the rear knuckle bushes and ball joints as well as organising custom brake lines. Hopefully can keep up this pace.
  • Like 4
On 7/3/2020 at 8:03 AM, ActionDan said:
Doesn't have to be pretty.
Just make it strong and let a flap disc sort the rest ;)
That's it, no one is really going to see underneath the car.
Calipers all finished off with fresh stickers and clear coat. Came up pretty good, not going to be a show car any way.
IMG_20200706_105100.thumb.jpg.040313caafe83db4bbb1d43be318cb4a.jpgIMG_20200706_105042.thumb.jpg.3a62e162c84880763f966616df88c99f.jpg
Finished welding the plates in and prepared the rest of the suspension for a coat of black.
IMG_20200706_145916.thumb.jpg.f432e1bb94cd2791bc8b51d542a8e46a.jpgIMG_20200706_145858.thumb.jpg.be2c250f53e128835076b5c5c9e5744f.jpg
Will let it cure for a day or two then start putting in the bushes and ball joints.
Also had the HQ tuned back in May. Made a massive 176hp ? drives pretty good for what it is, definitely needs the nitrous kit finished off. I had the timing and secondary set up right but needed a different power valve & mod to the squirters.
97461865_2912493985524841_720141182314741760_o.thumb.jpg.35d883cc9c77bd53caa585d59d0ac5fb.jpg97215725_2914221882018718_4358246672669605888_o.thumb.jpg.682ba42f4089666a453cb16b5de713a7.jpg
  • Like 4
59 minutes ago, iruvyouskyrine said:
Any tips to sanding and painting brembos? about to do mine
If you have the time and patience do a heap of smoothing to the casting and a base coat to get rid of all the imperfections. I sandblasted these did a base coat sanded with 400 then 800 and did final colour coat, apply stickers then cleared. I also wax & grease remover between each dry coat. All I used was vht brake paint from a can but if was to do it again would probably 2pac them.
Good luck with it, I'll try and post a link where I got my stickers.
Cheers mate. I only need to do the rears as fronts i purchased freshly powdercoated so i think VHT brake paint will suffice. Thanks for the tips, i hate painting but love the outcome haha.
  • Like 1
Rear end is in, all new bushes and gktech arms also cleaned up a spare diff cover and fitted it up. Had one f**k up installing front lca bush and bent the lca, lucky I have a spare but it's on the race car in Brisbane ?
Just need to clean up the threads for the rear sway bar mounts and that will be rear all done. Brake lines get measured first thing Monday so will be rolling Tuesday night. Actually getting keen to drive it. Excuse shitty pics but cbf after working on it all day.
**won't let me upload pics @PranK
  • Like 1
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
