Hi,
I got a boost gauge and am having difficulty figuring out where to place the hose.
I know that it goes after the turbo so I tried to place it on the nipple on the intake manifold which ended up making the gauge suck rather than blow into it.
I then found a couple of hoses which i think was where the factory boost gauge was/is. I am not too sure because my instrument panel has been changed and it has no factory boost gauge on it. I put the hose on there and it does work but its not accurate (i think) it only shows 1-2 PSI when i rev it from standing still.
I took a couple of photos, if someone could clue me in that would be superb thanks
https://www.sau.com.au/forums/topic/472244-need-help-installing-boost-gauge/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
