I've been doing research on cylinder head tech lately, and most of the info I find is either spotty or conflicting, ha ha. Any solid tech resources available for my reading pleasure?
The specific question I have at the moment involves which blank canvas to start with. I've read that the R34 NUR heads had some differences in water jackets for better cooling and air flow is a bit improved, but I can't find any definitive proof of that, or even an OEM part number other than the standard (11040-05U00). I've been thinking of ordering a new cylinder head to mate with my new N1 block (Planning on doing a Nitto 2.8 build), but I wanted to make sure I start out with the best OE head option possible (that's still available) before sending it off for machine work. Is there a different head available that's better? Or is it just internet lore and every RB26 has the same standard base cylinder head?
https://www.sau.com.au/forums/topic/472527-rb26-cylinder-head-options/
If you are wanting to do decent porting then just grab any head as it won't matter much anyway.
If you don't want to do any head porting etc then an R34 flavour head would (presumably) be best to start with under the assumption that the later models had better heads. Is it worth the extra hassle/cost of sourcing an R34 head over any RB26 you can get? Probably not. Best bet is just to get some decent/light porting of whatever series of RB26 head you end up with/already have.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
