I'm having a problem with a constant misfire at around 1700-2800rpm.
Tried and Swapped;
Unplugging tps
Cas swap
Plug gap 0.6 - 0.8 - 1.0
Swapping coilpacks with others
fuel filter
fuel pump
injectors
I've attached a log file and a video.
I have zero idea where to go from here... This problem is only evident on idle and at constant throttle around the 1-5% throttle.
4-11-2017_1915idlefluctuations.csv
Video.MOV
https://www.sau.com.au/forums/topic/472592-misfire-at-constant-throttle/
I have zero idea where to go from here... This problem is only evident at constant throttle around the 1-5% throttle.
Video.MOV
Prob not the same thing but mine acted very similar when i built it from 1000-1500 and was a pain in the but to take off from stationary.
turned out i had the intake cam 1 tooth advanced and when VCT  engaged it would hunt like yours and have no power. Disconnecting VCT or adjusting the TPS down a bit so VCT came in at a higher RPM kept it under control until i could pull it apart and adjust cam timing
  • Like 1
On 11/5/2017 at 11:20 PM, Guilt-Toy said:
put a fuel pressure gauge on the fuel line going into the rail and watch it when misses and look for any issues
Thanks, I'm doing that this weekend. It has to be something related to fueling.
I can't imagine it would skip a tooth, haha i hope not.
Haha I completely missed cell 67 - 72 - 113 - 172 - 220.
The tps is dropping out. Very prevalent today on the logs as it's getting worse over time. I tested so many things in the last week. I tested the voltage and throttle position percentage about 5 times each with nothing out of the ordinary, or more so that it was so quick, intermittent and sporadic that it never stood out.
The way we found out was watching the diagnostics window we could see the fuel cut go active and then noticed the tps was dropping out.
So i now need a new tps.
  • 2 months later...
Thought I should post my findings.
Changed the TPS, it was just a coincidence mine was wearing at the same time.
It was my transient throttle turning on and off and not having the correct settings. It was injecting a lot of fuel and the o2 was trying to combat it. Causing an oscillation in the afr.
All fixed now.
  • Like 1
  • Thanks 1
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
