Yo!
so yesterday my s2 R33 rb25det was working perfect never had an issue. i get in my car i go for a drive i go to hit boost and its struggling, it sounds like i have a bee r limiter but no power at all just making mad pops from the exhaust. the factory boost gauge shows its working but yeah no power and it struggles real bad.
i have checked all the piping and lines. no leaks or splits.
if anyone has gone through this or knows how to fix it please help. i just wannnaaaaa hit boost :(
https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/
stock ecu. 11.5psi. s2 r33 turbo. there is a paper in the car that its been tuned to 11.5psi. but doesnt feel like it. i changed the spark plugs seems to be working a little more better now. just gonna scope out for leaks with air compressor. i was hoping nothing shorted when i was using a light test and accidentally hit the smoke lighter and it sparked
hasnt been tuned for a few years. i have a dump and highflow cat and looked inside it no cermaic wheel bits. ive just put gasket maker for bov. tighten up everything else and install a boost a gauge tomorrow and see whats going on from there. its stopped misfiring. boosting better now. but feel like its lacking 10% of power i reckon but i'll let gasket dry over night and see how she goes in the morn.
Turn down the boost, your car isn't tuned.
You cannot tune the stock R33 ECU unless it has been remapped by Toshi or by those off the shelf remapped Nap ECUs (totally useless with Australia fuel and climate).
update* seems to be running better now. it ind of slacks but its getting there.
also i noticed after putting gasket maker for bov. when cold it kinds of flutters a little and makes a weird little metal noise after dose for under a sec. but once its warmed up it goes back to whoosh sound and no metal noise :/
strange. now its starting to do it again.
so when i put my foot down as it gets around 4-5k mark it looses power even with my foot on the floor it doesnt wanna go anywhere. i try it again and boost will come on i try it again it wont want to move... so confused
Edited by AndreW_R32
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
