14 hours ago, GeeDog said:
Just spoke to him, and he said that somewhere around $75 rings a bell. He bought it a few years ago. I paid an extra $20 or so to get the battery coding module a few months ago. He also bought the OBD adaptor from Carly.
Oh cool. I have a little bluetooth OBD2 thingo, I'll test it with Carly - thanks for the info.
56 minutes ago, niZmO_Man said:
I use "Torque Lite"
Yep, I have the full version of Torque. Even though my VW used a protocol that nothing could read (unless you spent hundreds of dollars)....
That seat belt looks like one of the ones in my Commodore. Of course, the Commodore's 1996 vintage... :P
I do love BMWs though, my first "want" car as a kid was a 635CSi, preferably in JPS racing colours. Maybe one day when the Alzheimers really kicks in I'll get one.
  • Like 1
Oh man, I have such a thing for 635CSi's. Actually, any classic BMW's.
Fixed the cup holder. The plastic that holds the spring had snapped. I was able to use a paper clip and some amalgamating tape to fix it. Stoked to fix and not have to replace.
  • Like 1
The other day we set the air recirc setting - default is that it goes back to fresh, but I wanted it to remember the last setting, set the nagging low fuel messages to the lowest km left setting, set the windscreen wipers to complete a sweep when the car is turned off (like every other car I've ever owned does), and disabled the headlight washers.
Previously we changed the light settings when locking & unlocking the car, set a digital speed display on the dash, removed the legal disclaimer on the NAV, coded a new battery, and several other things that I can't think of at the moment.
Carly can also reset service reminders, although this can be done without any outside assistance, using the buttons in the car.
  • Like 1
Hey @GeeDog do you find your passenger mirror is almost impossible to use? Mine is tiny and I can't see anything in it.
I'm wondering if it has the wrong glass - it might be ok if it was 'zoomed out' a bit.
1 minute ago, GeeDog said:
Mine's ok - it has a "split" glass, where half is normal, and the outer 1/3 or so is convex. As a motorbike rider I mostly do head-checks instead of using the passenger mirror anyway.
Thats funny. I was just telling my brother in law yesterday that I can't change lanes without head checks cause of riding a bike.
I don't think mine is split. I think I have the wrong mirror in mine.
  • 5 weeks later...
Gave it a big wash on the weekend and thought I'd take a few better shots of it.
I'm absolutely loving driving it. Its hard to keep to the speed limit cause it just wants you to go faster.
It hasn't all been rosy though.
The handling is odd. I believe I'm just a victim of run flats but its taking some getting used to. On a nice flat road its just gorgeous, but when there are ridges and pot holes it can tramline and pull a bit. I have been reading about my options for replacing them with normal tyres and either making room in the boot for a spare or carrying a small compressor + tyre foam stuff incase the worst happens. Prob is the Potenza's on it have SO much life left.
Can anybody else corroborate my run flats experiences?
My chrome window trims are super scratched and scuffed, so I plasti-dipped them black. Looked so shit, was so happy to be able to remove it straight away.
Also, I've found evidence of a terrible repair. So terrible that I'm almost embarresed that I missed this when looking at the car initially (though not nearly bad enough for me to not buy the car.)
The passenger side has had some kind of repair. The doors and bonnet trim gaps are a little off and there is a shit respray job done on the top of the doors. There is a bit of overspray and some paint coming off. The door jams and pillars are all original, so its just panel or paint damage thats been repaired. I'm not sure its worth fixing, but I would like to stop it getting worse, so I might just lay some clear coat on it. What do you think?
The first two pics are damage I did when I bumped it with my polisher, it just ate through. You can see some of the over spray in the third pic, but theres more than that.
Hi Prank, congrats on the purchase!
Like you, I’ve recently wandered into BMW ownership with an E90 320i.
Your right about the runflats, I’ve had the same experiences with them. Luckily the previous owner only just replaced them because I will not be buying them when the time comes around, I just can’t justify the price!
You can get runflat “repair” kits(previous owner got one)but it’s not advisable to do so haha
Oh I'm happy that you're hating then too (well not happy but relieved) because I was starting to worry about suspension components.
Are you loving the E90?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
