I cant handle the Serious Performance vids, the quality of cars and the footage of them doesnt really float my boat....still ill buy anything and they are all much better then the Max Power videos...the Hi Octanes are good for a laugh (only once) and i like the track and runway footage from the first few
Overboost is by far the best one they have done yet, even though it still does have some of the usual cheesy crap in it. But it does have them in cars from top Japanese tuners such as: Stillway, HKS, Veilside and Signal.
So how much % of gay footage is there to car footage in this one?
There is only about maybe 10 minutes all up of his story that goes through the movie.
Yeah, this one is maybe 10% crap - which is still more than I'd like, but its better than the previous one with the trip to the US which was pretty much 99.9% crap.
High Octane 4 is the 2nd worst car video I have seen (Max Power - Beasts From the East being the worst) and High Octane Overboost is the best...
2 guys from NZ like it but no one from Aus has said anything yet.
HEHE national pride?
That might be because its either not out in Oz yet, or just because no one has seen it there yet :headspin: Considering I think the first 4 standard out OK, then got progressively shite - HO4 being the best quality utter shit I have ever seen - I think I am pretty neutral.
High Octane Overboost is definately worth a watch. Don't ever watch HO4.
The serious performance collection are much better IMO
Yeah, cos I love nothing more than watching a moron in his airbrushed and wheelie bar equipped, nos bottle weilding swift/cino/barina putting around Oran park with no seat belt! :D:)
lol considering the most boring parts of the last DVD/'s were when they went to the aussie/ US car shows.
if i see another Cyber honda or one of those gay lancer coupes you guys have infactuations with (well not you guys as you own skylines, but other guys) i think ill scream-
HO5 was great, better than the last BS one.
Alot of the other stuff in them is more relavant to us though, as its local.Hence why you probably find it boring. Pretty much works both ways as we have very different car scenes in our countrys.
I'm australian and I like High Octane
I think its just a different view of performance cars. I like the comical aspect of it.
I actually think that ketzal, while being stupid in some parts is quite funny. overal I like the dvd's (4 was a bit crap) and I own all 5
the whole thing is they aren't really a serious hardcore look at performance cars, if you want that buy HPI or something similar.
you can't say teh MR2 and GTS4 aren't hot though
mark
Ok finially got around to watching overboost and its preety farking good.
Easily the best high octane they have released. Just the japan trip is worth paying for it.
I also got Best Motoring 11 and that rocks to with the testing of the new Galardo against the F360, 911 GT2 etc.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
