Bullus Posted April 3, 2018 Share Posted April 3, 2018 (edited) I have a 2002 M35 Axis by Autech 2.5l turbo AWD Stagea and have to replace the shocks and tie rods. Does anyone know part numbers for Axis variant or failing that, am i able to fit the BC BR coilovers and ordinary AWD M35 parts as replacement on the Axis, not sure what the differences with suspension between Axis and normal are. Thanks Andrew Edited April 3, 2018 by Bullus Link to comment https://www.sau.com.au/forums/topic/473694-m35-axis-suspension-question/ Share on other sites More sharing options...
admS15 Posted April 3, 2018 Share Posted April 3, 2018 I dont think there is anything different about the axis shocks compared to a normal stag, Arx versions sit higher. BC BR will be fine. Link to comment https://www.sau.com.au/forums/topic/473694-m35-axis-suspension-question/#findComment-7871704 Share on other sites More sharing options...
TukeH Posted April 4, 2018 Share Posted April 4, 2018 Why would you buy the br coils when the v1 bc coilovers are basically the same coils but cheaper and you cant even adjust the camber from the top in m35 stageas. Link to comment https://www.sau.com.au/forums/topic/473694-m35-axis-suspension-question/#findComment-7871754 Share on other sites More sharing options...
Bullus Posted April 4, 2018 Author Share Posted April 4, 2018 43 minutes ago, TukeH said: Why would you buy the br coils when the v1 bc coilovers are basically the same coils but cheaper and you cant even adjust the camber from the top in m35 stageas. from what i have read the BR are slightly better and only $100 more Link to comment https://www.sau.com.au/forums/topic/473694-m35-axis-suspension-question/#findComment-7871758 Share on other sites More sharing options...
admS15 Posted April 4, 2018 Share Posted April 4, 2018 The br also has a slightly larger diameter piston and shock body. For $100 extra its a no brainer really, unless your strapped for cash.@Bullus kudos motorsports stock tie rod ends for M35, you can get the part numbers off their web site. Link to comment https://www.sau.com.au/forums/topic/473694-m35-axis-suspension-question/#findComment-7871760 Share on other sites More sharing options...
Ryugen Posted April 15, 2018 Share Posted April 15, 2018 Sorry if I'm hijacking this thread. I've just done about 2 hours of old thread digging and can't find a clear answer only hints. Looking at getting Whiteline sway bars, specifically the BNK006 kit. Everywhere officially states that this is a M35 RWD only kit however I've seen snippets that say there is no difference but then other threads saying the fronts are different. Can anyone confirm or deny the sway bars are the same fitment for RWD and AWD M35 models? I have a M35 AXIS Autech VQ25DET. Thanks! Link to comment https://www.sau.com.au/forums/topic/473694-m35-axis-suspension-question/#findComment-7872686 Share on other sites More sharing options...
