Im trying to fit an analogue cruise control kit to my 07 V36
Does anyone know where to find an analogue speed sensor wire for an 07 V36?
I've searched high and low through many g35/g37/j50 FSM and cant find any wiring remotely close to the JDM Skyline cars.
I've also searched on here to no avail.
Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/
If you put cruise control into the search box you will find a couple of Stagea owners have done it on their NM35s - ok not a V36 but still drive by wire...
  • Like 1
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/#findComment-7871896
When I mention I've searched the above FSM, they all show a red speed wire going to pin 28 @ the a/c amp/unified meter, (for the trip computer data) but my(our JDM) cars dont have the same wire in the same spot, which I was hoping if anyone else had come across this and solved this problem.
Yes I know of this, I have done this in my Stagea, and now wish to do the same in my V36.
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/#findComment-7872022
  • 3 weeks later...
I know I'm a bit late to this party but since people have been nice enough to help me out with a question earlier this week, I thought I'd contribute to this one.
Not sure if you've had any luck since but most certainly one of those wires going to the A/C and Instrumentation Amplifier will be your speed sensor. The only way to be truly sure though is to grab an oscilloscope and measure the waveform. I haven't got the FSM handy on my laptop but when stationary, the signal should either be constantly high or low and when in motion, you should see a pulse train that increases in frequency proportional to speed (you'd need to have the rear wheels up in the air or on a roller dyno of sorts to confirm this though). Basically, the pulses should start to pack together closer as speed increases.
That's how you'd find it without any reliable documentation. It's similar to the park brake wire (also going to the same unit) I had to find for a device I built, where it wasn't in the place the FSM indicated, so I had to sniff it out with a multimeter and see which one changed between active low and high.
  • Like 1
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/#findComment-7873851
I haven't had much luck yet; Been a bit slack and a bit nervous probing back there even though I do have some US FSM.  I was even given a probe extender (a wire with a sharp point on one end) so it would make the job easier.  I just have to get the courage to get in there and test it for myself.
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/#findComment-7874915
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
