Hi all, been trawling through pages and pages and I can't find answers to all of my questions so I'm hoping to get some help in this thread.
Background, I have a 2002 M35 Autech Axis that is due for a brake change (front pads and rotors are gone). I've managed to find a set of 350Z Brembos (cause why replace when you can upgrade) for a decent price and am just trying to get some more information before making the jump. From my digging, this is what I've found:
  • Should be a direct bolt on however R34 GTT threads mention modification to the dust fan / bolt but unsure if the Brembos will face the same problems
  • Information points to that the 18" Autech wheels might not fit but can't find confirmation
  • Have seen no mention to the upgrade affecting ABS
  • #justdoit
What I wanted to know are the following:
  • How bolt on is bolt on? Will the same changes need to done as per the R34 GTTs? Is there a guide somewhere specific to the Brembos?
  • The kit comes with calipers, rotors and lines. Will that be all I need besides the pads?
  • Anyone to confirm the 18" Autech wheels will/won't fit the Brembos
Thanks!
- Yang
https://www.sau.com.au/forums/topic/473716-m35-350z-z33-brembo-upgrade/
Yang,
Straight install with the only modification being removing the outer lip on the rear backing plates to fit the rotors.
I've got them installed on my 2001 NM35 250T RS 4.
Also, you may need spacers for the front depending on the offset of the wheels. I had +38mm offset Yokohama AVS 18"x8" rims fitted to mine so needed spaces to avoid hitting the caliper. Now I've got 19"x9.5" rims so not needed. I still have the 5mm spacers.
Russel
Hey Russel, thank you so much for the reply much appreciated. Good to see it's a straight forward change. Judging from your wheel history I will probably need to invest in some spacers. The Autech rims are 18 x 8 +30.
On 5/1/2018 at 3:41 PM, RS_Wags said:
Have you got them on yet mate? I'm looking to put Z Brembos on my M35 too.
Hey, yeah I had them fitted last weekend. They are as bolt on as they are going to get. I got calipers + 350z lines + bolts and they all went in as you'd expect. The biggest pain was the wheels. The 18" AXIS wheels on the front don't clear the calipers. We did a big run around trying to source spacers. 5mm worked great and leaves about 1mm clearance sooo super tight. YMMV with other wheels. Rear wheels cleared with room the spare.
Only "adjustment" we had to do was cutting and bending the rear dust protectors.
All up calipers + new rotors + new Brembo pads cost me about $1,650ish
Hope that helps!
19 hours ago, NicPM35 said:
I would avoid slip-on spacers like the plague!
You lose 5mm of lug thread and also shift more weight from the centre bore on to the lugs themselves.
And assuming WA laws are the same as everywhere, they're most likely illegal.
16 hours ago, KiwiRS4T said:
^^^ what he said. Get some 10mm hubcentric bolt on spacers.
Oh 100%, I've got hubcentrics coming in but the 5mm slip ons were the only ones we could find same day that would allow me to drive home.
Hope that helps!
Thanks man!
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
