Not quite.
Decently powerful CA is also going to shit the box so Z32 or RB25 is expected either way, diff we'll wait and see.
Faster car regardless of engine warrants bigger brakes and better tyres (so larger rims and 5 stud swap).
Those things happen either way.
An engine build, CA or SR is actually around the same money using the same basic forged parts and new OEM things. Might as well go the newer, more torquey platform with better support.
Thanks and bye :)
On people airing their opinions, that's OK if they are on topic but can be quite annoying when posters air opinions that in reality are what they would like or prefer and have nothing to do with the OP. It also helps some people when trying to make a decision to write down their thoughts, relevant responses help in that process.
Only comment I have is not to forget to check things like can your present box type can be upgraded, same with the brakes eg better cooling, better pads, better calipers, etc. You have a low weight advantage that is quickly going to be lost if heavier bits like a 32 box are fitted. There is something to be said for optimising what you already have, it's the package that's important, maximum performance with minimum weight.
To upgrade the box would be 5k for a gearset, z32 box swap is 3.
Better calipers means 5 stud for the rotors I need to fit them.
I get you though and that's part of the whole decision, how far to take this chassis vs cutting my loses.
Of course optimising what you already have will cost you more and thoroughly investigating weight and cost is part of that process. What I find is that most don't do this thoroughly but instead take the easy well known option which is not always the best. Let's take brakes. Have you searched every option available? There are online sources such as Ceika who offer a wide range of kits, their stuff looks to be good quality but I have not used mine yet. Their downside is that the adapters are made of steel and can be heavy depending on how big they are.
At least you choice is clear, optimising what you have or go with a heavier more powerful car that may or may not be faster, depending on the circuit. On the subject of circuits, go to as many different ones as possible. How about Bathurst in November?
I tend to just look at the cost effective options.
I could buy a new big brake fit, but Brembo calipers and rotors from an Evo or GTR will be much cheaper and on a light car fairly effective.
Gearbox can get away from you, tti would be nice but at 8-9k, the z32 box is a third of the cost.
Basically you can't afford what is needed, this is probably why some commentators get frustrated. There are heaps of things that you could do like big wide wheels, MCA suspension but if it all comes down to the $ then it gets to be a personal thing. You just can't expect to compete with the $ cars, what you can do is keep tweaking what you have and enjoy the challenge of different circuits. Race against yourself, you can always do better.
Oh I can afford it, but I always try to be smart with my $$$
15-20k for mods to this car or 15-20k for another car and sell this one.
I just don't know what the right/best/smartest choice is.
I get frustrated with myself just as much lol
The hardest thing I've found is accepting that in spending money on a race car means basically saying goodbye to it. That's OK when it's just a few dolla, it's the big chunks that hurt but if those big chunks work then over time then I'm pleased with making the right choice. It's usually when I've tried to compromise that mistakes are made. My philosophy is if the money is spare then spend it, if motorsport really is your thing then do it while you can.
One example for you, go five stud and get a really good aftermarket brake kit, two piece floating rotors, the lot. You S chassis people are spoilt for choice.
  • Like 1
Appreciate the time and thoughtful responses.
This thread has been good, Also had a chat with the missus, who tolerates and understands my little eccentricities.
I think I'll keep developing this chassis.
I want to do certain things my way and I already know all the ins and outs of this setup. It might cost a little more, but it will be done how I want it plus I'll get to try a few ideas I have that are best done during build phase.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
