Hey guys, im new to skyline Australia and i would like some help.
My skyline r33 is losing power when i flat foot and the rpm reaches 5000rpm or so. Recently the problem has seem to evolve and make the car die out past 5000 rpm and what i mean is, the car is still on but there is no power what so ever past 5000. I've had this problem before except the dying out part and i fixed it with AFM. I have bought 2 AFM's and put them in the car and reset the ecu, however the problem is still there but the car dying out problem seem to be gone. Does anyone have any advice on what i can check next please. Im a student so i dont wanna go out and spend more money for nothing.
My car only has a few mods: (STOCK ECU + BOOST-no boost controller)
1.Spitfire coils packs
2.FMIC
3.After market fuel pump KEMSO 340LPH
4.Exhaust system turbo back
5. Iridium sparkplugs that i replaced about 6-8months ago. (Have not touched the gaping)
Tomorrow i will check the coils and spark plugs, but is there anything else i can check? Ive also checked previously for air leaks but found nothing.
Can timing belt be an issue? and o2 Sensor?
Thanks!
Rany
https://www.sau.com.au/forums/topic/474144-dying-at-5000rpm/
Partially collapsed cat or muffler or flattened exhaust pipe can do that,  had a Falcon that started doing this at higher revs then one night on the freeway it fired a blazing ball of muffler packing out the tailpipe and became much louder.
14 hours ago, wildeagle44 said:
Maybe bypass the knock sensors? Could be pulling timing.
Does it happen in every gear?
This time it is happening every gear. I cant flat foot on any gear from 1 to 4 so i'll check it out. would you know where their located?
Thanks mate
12 hours ago, BBGTR said:
Sounds like the igniter module, they sometimes break down at higher revs when they get old.
Thanks mate i'll have a look into it today.
The data sent from the car’s oxygen sensors to the computer helps it adjust the air-fuel mixture for optimal operation. If a sensor is bad or failing, the computer won’t be able to adjust this mix correctly. Also a clogged fuel filter can cause similar symptoms. Combine the two and you are in a world of pain. A new fuel filter is a cheap starting point buddy.
Thanks for the reply Rusty. I have bought a new 02 sensor. Im gonna change it, if it fixes the problem im happy if it doesnt then i will just changed a part that is over 20 years old. I will also buy a new fuel filter since my 1 is still the original im sure.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
