11 minutes ago, 89CAL said:
What is the problem specifically? You can buy the harness from the plug to the light FYI For about $25 each
Replaced mine a while ago
I'm planning on doing a Bi-Xenon retrofit soon.... The plug looks like a generic automotive connection. I'm just trying to the the specifics on the type.
5 minutes ago, 89CAL said:
There was a site you could buy all the different connectors from. I cant remember it unfortunatly.
Im not much help lol
Lol that's ok. I've seen the connection all over Google images, just not with a specific name.
I'm doing a quad projector setup. Making sure, I have my connectors right, for the splitters.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
