Hey guys I need some help from some fellow members I’m in the next stage of my build and that’s suspension the car is my r32 four door but I need to lay the power down to the rear what suspension is every one running these days ?  Rang just jap talking to them they recomaned bc coils but I am open to options the car will be setup for drag racing the set up now is way to hard
https://www.sau.com.au/forums/topic/474230-r32-4-door-drag-set-up/
First you need to fix the subframe.  The anti-squat geometry on R32s is the enemy of drag traction.
After you've replaced it with an S14 subframe, put a full set of adjustable arms into it and ensure that they are dialled in for minimal camber and as little bump steer as possible.  Then speak to MCA about some custom valved coilovers.
Yuh, but the subframe is essentially the same as the GTSt subframe.  The stuff that's bolted to it is not responsible for the geometry.
And the GTR diff isn't "stronger" than the GTSt diff.  Yeah, sure, it's a mechanical LSD, but then anyone dragging a non GTR is going to put a mech centre into the GTSt diff anyway.  And the 6 bolt axles are only marginally stronger than the 5 bolt.  So, go ahead and put that stuff in if you want to, but don't make the mistake of thinking that it's a major upgrade in terms of strength.  And do not make the mistake of thinking that the GTR subframe is better than the one that you have.
In the R33/4 and S14/5 cars, the suspension geometry was significantly improved over the R32 & S13 era cars.  And the S chassis cars don't have HICAS, which is worth getting rid of for any car, but certainly good to get rid of for drag.
agree with all above
I dont know what power your going to run but I have personally run  high 500's hp with rb25 in both drift and circuit in r32 4 door with all of the above and have never had a problem with axles etc (I know drag is a little different with launches)
then if anything you can spend the same money getting s14 subframe + diif + below upgraded axles for a better outcome than circa $1000 - $1500 on the full rear GTR cradle
http://www.driveshaftshop.com/import-axles/nissan/skyline/nissan-rwd-gt-s-and-variants-rear-axle-bar-upgrade-bars-only
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
