Alrighty gang, up for sale are my set of BBS LM's in 18x9 with the faces reversed for a (estimated) +5 offset. Perfect fitment on an R32 GTR. Will also suit a whole range of 5x114.3 cars.
I spent far too many hours getting these up to scratch polishing and flipping the faces (done correctly, loctite'd bolts and torqued to 30 n.m) so my loss (of time) is your gain.
Two wheels have some rash on two wheels, two are fine.
Tyres have almost full tread, but are very old. one tyre has a little chuck out the middle.
Last pic is fitment on a 32R.
Located SE Melb
Please pm me or text on 0424four90187 for any more info or questions. Wont reply to texts tonight as I'm at uni cramming for exams with no service inside the buildings so pm's preferred.
IMG_0704.jpgIMG_0707.jpgIMG_0691.jpgIMG_0683.jpgIMG_0698.jpgIMG_0687.jpgIMG_0699.jpgIMG_0151.jpgIMG_0084.jpg
Edited by Hardwork
forgot tags
https://www.sau.com.au/forums/topic/474274-gtr-bitsr32-bits/
Hey guys, bought this couple weeks ago but is no longer required.
Used, but reusable and comes with brand new clutch disks. Havent opened it since I recieved it.
Includes everything but flywheel bolts.
easily the most street friendly twinplate, drives like stock and is rated for 544kw.
model number: 3002A-RR593-C
Price is $1400, $170 less than what paid, and almost half the price of brand new.
Located SE melb. Please pm if interested.
Edited by Hardwork
forgot tags
Hey guys, trying to offload some bits to fund the new car.
up for grabs are;
Invidia catback 85mm (3.35 inches) for a R32 GTR - $450
RB26 engine covers full set, suit respray/powder coat - $700
Rebuilt R33 GTR turbos with steel rear turbines and HKS actuators with less than 5000km use, minimal shaft play and stock dumps - $500
R32 Dash mat - brand new with packaging - $50
I also have two other threads running containing:
BBS LM's in 18 x 9.0 with reversed faces for a +5(ish) offset, perfect for a 32R - $2800
Nismo Coppermix Competition Twin plate Clutch (PUSH TYPE) - $1400
So check those out if you are interested.
Please pm me for more photos and details.
Located SE Melb
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
