Since their answer regarding my issue has taken over a week, I feel that a heads up regarding reimax oil pump gear clearance is justified. Found some old threads with this issue, then some newer ones stating that it's fine, and went for the "cheap" solution.
This is the fitment of the uprated oil pump (over 0.45mm, got a 0.05 feeler gauge blade stacked beneath) on a brand new crank.
Let me know what your experience has been with Reimax or similar solutions!
Now, I'm waiting for a spline drive kit.. Don't do the same mistake as I did, the expensive solution will just cost even more :whistling:
(I lost oil pressure which led to bearing failure, and the crank needed a lot of work to be ok again. Someone, at some time, fitted a narrow nose crank in my late -93 R32. The oil pump chewed some small pieces of the bearing so it too had to be replaced or repaired.)
10 hours ago, KiwiRS4T said:
So have you measured a stock pump? What downside do you fear?
Not stock, no, but the N1 pump that's been in the last 8000 Km. N1 got somewhere just over 0.30mm but it still showing signs of wear on the edge where it usually breaks. I want to feel "safe" pushing the engine, and since the pump had to be replaced or upgraded, I thought "better safe than sorry" and bought the salespitch. The gear might be up to the task, but it just seems too much.
So, for all you who prefer thou to mm, reimax: ~18 thou and N1 ~12 thou.
Edited by K_arlstrom
I dont know anything about engine building, but if the reimax gear is made from a different material to the N1 gear, then it could have a different co-efficient of thermal expansion and therefore require a different clearance. That's just theory tho - I have no intuition on whether its a likely explanation in this case. Let us know when they get back to you.
21 hours ago, K_arlstrom said:
Shameless bump to see if it's possible to start the discussion.
Got a reply today where they claim this is as intended, would you feel ok with this much play?
Well yes. It would be very easy for Reimax to make their gears with a smaller clearance so I assume they know what they are doing. You have reported that the length of the crank nose  was the problem last time ...not the amount of clearance.
On 8/25/2018 at 5:24 AM, MrStabby said:
...different co-efficient of thermal expansion...
Fairly similar from what I can find, not close enough to stop it from lashing back and forth. They state that it's normal, but they didn't want to give any recommended clearance or warranties, "If it works, it works, we got out money" is how I read their reply.
Old pump didn't break, but were visibly worn where it's reported to break. Since I'ts an engine out job, and the pump had bits of bearing in the cogs, I wanted a solid replacement to never have to think about it again.
Anyways, everyone who has read the thread seems to be ok with Reimax gears and the, IMHO, massive clearance. Keep an eye out for it at a bargain price on ebay ;)
Well that's not cool.
What the factory clearance? On page EN-96 of the shop manual, it says "Measurement position 5 is the figure obtained by subtracting the housing flange outside diameter from the the inner gear inside diameter" and shows a micrometer being used on the inside of the inner gear. If "housing flange" is some weird engrish for the crank mating area, then the clearance is 0.045-0.091 mm (0.0018-0.0036 in)...
Well according to the above the Reimax is well within spec. The last thing you want is the pump seizing on the crank.
I used the Reimax gears and have had no trouble. They also had the large clearance I assume too that Reimax know what they are doing since they built the Clasonic GTR back in group A days. Is there evidence that the large clearance is a problem, I think it is a good thing for crank flex.
  • Like 1
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
