39514774_234901520553778_6351200665829638144_n.png?_nc_cat=0&oh=b9be95f6d4077b304e9c7f6784fdab22&oe=5C10EDB4
That time of the year again for one of the best days you can have at Sandown.
SAU VIC has been lucky enough to host Round 5 of the CAMS Victorian Supersprint series, for more info visit: http://www.vssc.com.au/
Date:
Saturday 29th September AFL grand final day.
- For anyone interested in attending their first track day here all you need to know : http://www.sau.com.au/forums/topic/453779-track-day-requirements/
- Car must be fitted with an in date (Manufactured after 10-2015) Fire extinguisher bolted to the car using a metal bracket. Not screwed or cable tied.
- Full length clothing and helmet in date
Licence:
You will need a CAMS L2S licence to compete on the day + a VALID CAMS affiliated club membership.
Or L2S can be obtained via https://www.cams.com.au/
Sandown International Racecourse
591-659 Princes Hwy, Springvale VIC 3171, Australia
Map: https://goo.gl/maps/QmzXvoRDqUm
Time:
Gates open 7:00am ( the quicker we get cars scrutineered the quicker we can start)
We will try to have all cars scrutineered by 8:45am for drivers briefing
Finish 4:30pm or when people retire
Entries:
Capped to 89 entrants
Entries close: Thursday 27th of September at 11am.
As this is a VSSC Round you will need to nominate what category your car fits in (Details are in the supp regs)
Early bird discount (Valid until 17th September)
$235 SAUVIC and WRX Club Financial members (make sure you put down your club member number for verification)
$255 all other club's entries
Late entries (from 18th September)
$285 for all entries after
Enquiries:
Any questions about the event email [email protected]
If you would like to book a pit garage contact Brendan on 0403 189 352. $50 cash on the day directly to him.
Supplementary Regulations Must be read before event and can be found on the entry page
Disclaimer to sign on the entry page
EVENT ENTRY HERE
Entry list:
Pat Di Fiore    Mercedes Benz CLK63 AMG
Clive Small    Mazda MX-5
Ross Macdonald    Ford BA XR6 turbo
tim donoghue    FORD AU
Kristianto Halim    Renault Clio 3 200
Graham Harvey    Nissan S15
Andrew Gott    Porsche
Simon Dalziel    Nissan S15
Steven Bonner    HSV Clubsport
Travis Trayhern    Nissan Skyline 250GT
James Grant    Nissan Skyline R33 GTR
Benjamin Trembath    ford falcon xr8
Peter Owen    1971 Ford
Clayton Sinclair    Nissan 300ZX
Ash Stacey    Nissan GTR
Ewen Moile    Datsun 1600
Michael Ban    Ford Fiesta
Robert Resuggan    Chrysler 300 c
simon feil    Nissan Skyline 250GT
Michael Garden    Nissan Skyline R33 GT-R
Tim Williamson    R32 GTS-T
Matthew Doyle    Mazda 121
Darren Odgers    Morris Mini Cooper S
Haydn Morrell    Porsche 911
David Webb    Toyota MR2
Jack Ippolito    Hyundai Excel
Rene Cote    Honda Integra
Aaron Doble    Skyline R33 GT-R
Glenn Vardy    VY HSV
Greg Lynch    HSV GTS VT II
Tim Blakeney    FORD FPV
David McCann    Datsun Stanza
Stephen Emery    HSV
Adrian Jarvis    HOLDEN VF
Hugh Feggans    Porsche
Huy Phan    Nissan 200SX
Bill Dalianis    R33 GTST SKYBOAT
David Blunden    Skyline GTST
Eddie Stallard    R34 25GT
Greg adshead    Bmw e46 m3
Stephen Douglas    Mitsubishi 380 VRX
Mark Wilson    Ford Falcon
Sam Lehmann    Skyline GT-R
Jason Carey    Skyline R33 GTST
Michael iudica    R33 Skyline
Steve Larsen    Ford Falcon EL
Jeff Beable    GTR R34
Adam Orr    Subaru WRX
Daniel Nicolici    Nissan
Dan Mayers    Nissan R33 gtst
Phil Williamson    Nissan R32 GTS-T
YI ZHOU    Volvo S60 Polestar
Alexander Cheung    Renault Clio
Grant Ellers    BMW E36
Ben Lascelles    SUBARU WRX STi
Peter Blythe    Nissan Skyline
Steve Quilliam    Holden Commodore
sandown-aerial-current.jpg?la=en
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
