OK so turbod my r34
Rb25de neo car is half tuned as turbo blew and spent all my money on a new one haha OK so I'm not happy with the knock levels bad timing set 15btdc have set all timing in map to low but so bloody hard trying to get power without knock the load timing is hurting my brain haha most of my map I set to 18 load and rpm and upd injectors Correction from 1000 to 1400 barley any knock but just all feels crap so was wondering if anyone had a pic of there maps I can copy just for a base start for rb25+t 5-10psi and maybe injector map thanks people
R33 5speed gearbox conversion
R33 rebuilt turbo
R33 turbo manifold
Gtt injectors
R32gtst4det fuel pump
Power FC ecu and controller
Big front mount cooler
Turbo smart bleed valve
New 3"pipe decat and r32 custom dump
R34na 02sensor
R34 na pink label afm
https://www.sau.com.au/forums/topic/474742-rb25-det-ignition-maps-boost/
If you want to tune with PFC, source yourself a Datalogit kit, wide band sensor kit, and from there you will get the right fuel map developed to suit your engine and injector flow capabilities.
Is the AFM from an N/A spec capable of measuring the flow of the turbocharged setup?
Ignition wise, you've got relatively high static compression, and a fairly restrictive turbine.  That's going to impact significantly on what timing the engine will take under boost without being prone to knock. On P98, you're going to have to test - carefully.  That timing might be only 5-10 BTDC.
And that's why E85 could be your friend if you want it to make reasonable power with a DE+T.  ie. you need timing in order to make best torque. But put too much in, and you'll be looking at blown ring lands.  The resistance of E85 to knock (compared to petrol) makes life easier.
Cruise + light load ignition mapping, you will comfortably be up around 35 degrees (some will use more than that even).  Then it's a case of pulling that back as you approach and get into  boost.  This is not something I would encourage you try to get perfect on road, especially as a novice tuner.
It could prove costly, either wreck an engine, the car, someone else, or your licence because of the varying conditions/speeds/loads you need to exercise the engine to log and build your tune file.
I no longer have any PFC files that could assist.  Have you looked at or found any tuning groups on fakebook? Better still, any groups that only play with Power FC?  Or considered a tuner who plays with PFC?
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
