Hi,
Just wondering what other Nitto 3.2 owners are running or their heads? My 3.2 will be built in a few weeks, and am pondering on how much to spend on the head.
I have a 9180 with a 1.01 hotside. Will be looking at flex fuel as well.
What mods to the head are you guys running please? I have also bought a brand new head. So far I am thinking:
Cams
Tomei Cam gears(Already have)
Supertech dual valve springs with Ti retainers(kit)
Valve guides
Stem seals
I am also going to get the head ported and cleaned up where necessary. I don't intend on running more then 2bar, as the shaft speed will probably exceed 118k~.
How far are you guys going in terms of porting and head work? I understand that the stock head will give me loads already, however a light touch up wouldn't hurt.
https://www.sau.com.au/forums/topic/474793-rb26-head-build/
Depends entirely on your requirements. If it is a street car "a light touch up" will do nothing for you.
How much power do you want ? How fast do you want to spin your engine? Street, drag strip or circuit racing? An all out race build will be no fun to drive on the street.
Any head work that is effective will cost an arm and a leg.
But regardless of cam choice adjustable cam gears will give you more tuning options.
  • Like 1
https://www.sau.com.au/forums/topic/474793-rb26-head-build/#findComment-7883996
My heads being done atm for my RB34 running a precision 7675. It has the following:
Ferrea os valves, bronze guides, kelford beehive springs and ti retainers, race port and just general stuff like a deck, seat cut, valve seals etc.
If you're going to port it definitely get the lumps removed on the exhaust side and smooth out the bowls. My machinist calls that his street port. It's around $800 for the street porting if I remember correctly
https://www.sau.com.au/forums/topic/474793-rb26-head-build/#findComment-7884180
Thats fantastic, thank you so much. I spoke to a head machinist company, and they pretty much had said what you said about decking/seat/angles etc etc.
What cams did you choose just out of curiosity? Feel free to PM me if you like. I'm possibly going to go for 280/280, but not 100% sure yet.
https://www.sau.com.au/forums/topic/474793-rb26-head-build/#findComment-7884201
You're on the waiting list as well. I've been recommended the 182-SE type that will be available Nov. Might work out as I intend on doing other things while my motors being built.
How difficult was it to remove the AC lines and refit them for your bay respray? I'm actually thinking the same, although I have ABS, so that might be a bit of a pain.
https://www.sau.com.au/forums/topic/474793-rb26-head-build/#findComment-7884348
Nah a/c was easy, there wasnt any gas in em so just popped em off pulled the boots off and the painters taped it all up. I pulled my brake lines out as well. Just have to rebleed them when its closer to driving.
https://www.sau.com.au/forums/topic/474793-rb26-head-build/#findComment-7884424
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
