HEY ALL,
I'm new to the scene,  finally a PROUD SKYLINE OWNER !
I hope i'm writing this in the right topic as i'm not much of a forum guy and my English is not the best either.
Now i have been wanting to buy a skyline for the last 15 years at least ( i'm 33 now) i'm from Germany originally and it was an utter fortune to get one over there.
As i made Australia my home now my dream finally came true.
So i recently purchased a bargain manual   R34 GT-T , rb 25detneo with 106000-km and its pretty much factory stock.
- Now i'm getting a a high  but steady oil reading at 135c after a few minutes driving (normaly :-D)
- also the water reading is at 120c (steady)
The engine seams to run super smooth the needle doesn't move in idle,  there are no noises from the engine what so ever.
the oil gauge on the main dash sits less then halfway .
I got a service done after purchase at a trusted mechanic (even though he said he doesn't really know (those cars) ?
the only issue he mentioned was a small oil leak from the O-ring at the Oil-Cooler and also a small oil leak from the engine rocker cover gasket.
Now after a lot of research i was hoping to get some input from you guys on what to do.
i have order a new engine rocker cover gasket still trying to find the O-Ring, to get that sorted,  but i'm not shure if that will fix the high readings , should i just go and buy a quality OIL cooler (not the cheap shit)  and maybe a good water-pump?!
Also can anyone recommend a mechanic with skyline experience in the Sydney area ?
JUST-JAP gave me a number to call  of one of their trusted mechanics but he never seems to pick up the phone :-)
Thanks for reading any help would be much appreciated !
Thanks
Pete
https://www.sau.com.au/forums/topic/474818-r-34-gtt-oil-and-water-temperature/
Those readings are what you would expect after a hard track session - not just driving down the road. Get a temperature gun and see if the engine is as hot as the gauges suggest - they could be wrong. And persevere with your efforts to get an experienced RB mechanic - the good ones are always busy.
Is this car actually stock?
I saw this behaviour when I had a R34 GTT and someone had replaced the standard triple gauges (in the center) with aftermarket gauges.
However they had just repurposed the OEM wiring and sensors, so all the gauges read incorrectly. Given the car does NOT have a stock temperature gauge that reads (in C) how hot the car is, it makes me wonder if these are aftermarket gauges that are setup incorrectly.
But I definitely remember the oil one - It read very similar numbers to that until I changed the sender to the correct sender.
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
