• Welcome to SAU Community
    Welcome to SAU Community, like most online communities you must register to view or post in our community, but don't worry this is a simple free process that requires minimal information for you to signup. Be apart of SAU Community by signing in or creating an account.
    • Start new topics and reply to others
    • Subscribe to topics and forums to get email updates
    • Get your own profile page, build reputation and make new friends
    • Send personal messages to other members.
    • See fewer ads!
    Consider joining our newsletter for the latest content updates
    Click here to register
BK
nt  RB26 GTR parts, Nitto 2.8 billet crank, MODIFIED TRANSFER CASE, Trust / Quaife 6 speed dog box
Nothing, except the Quaife rear diff centre of course. Bolts up to any GTR driveshaft axles, except R33 and R34 v spec active diff shafts as they are shorter. Any GTR non active diff driveshafts will bolt up, correct length. This is my spare set I don't need and used same setup. Installed it on my 32 earlier this year when I put Quaife front and rear diffs in.
Share this post
Link to post
So the diameters of the shafts are the same and will just fit into the old 32 housing no problems?
Who did you use to install the diffs? If you dont mind me asking, since Award is no longer.
Share this post
Link to post
There is a 1mm diameter increase in non splined shaft area from 32mm (30 tooth) to 33mm (31 tooth) and 1mm approx. increase in diameter on spline from 30.9mm (30 tooth) to 32mm (31 tooth). No problems with housing clearance as the increase is all to do with the diff centre bigger spline change. The speed sensor 46t outer and 6 x 1 flange pattern and dimensions are the same.
My father who is a mechanic and has his own workshop did the diff install. Don't have the luxury of 100s of workshops here in Alice Springs like on the east coast. He's pretty much the resident RB26 / GTR guru here in town. Not a lot he doesn't know about them or how to work on them. He is the assembler of the OS giken box for sale here also.
Share this post
Link to post
Nismo thermostat - SOLD
Nismo radiator cap - SOLD
Tomei block restrictor - SOLD
ATS clutch discs and pressure plate sold pending payment.
31t rear half shafts sold pending payment.
Share this post
Link to post
All PMs replied to.
Fresh 10 plate (standard is 7) modified transfer case is now completed and up for sale. Like new inside and reset back to factory new tolerances. New drive / friction plates, new strainer filter, new oil pump o rings, new retaining and pressure plates, shimmed back to factory 0.2mm - 0.5mm (8 - 20 thou) drum clearance as per required tolerance (around 13 thou from memory).
$1500
Share this post
Link to post
Just added for sale Trust / Quaife 3F1 6 speed H pattern straight cut dog box with freshly modified transfer case added for sale.
$8500 ONO shipped anywhere (possibly throw a clutch in there with it with the right buyer).
Going sequential so not needed - make and offer !
Share this post
Link to post
