That is one of the straightest chassis rails I've ever seen on a 32.......next time put the stands where that seam is (forward of where you used), or spread the load a bit with a piece of wood along the rail
  • Like 1
you could....but I cant see a dangerous amount of bare metal there.  If you look at other places like the spot welds where the chassis rails meet the floor you can see how a touch of surface rust can start over 30 years. It's not a dangerous rust risk like some places where water can pool and really eat into the metal.
If you are worried underfloor sealer (tarlike stuff) is available in cans, it resists stone chips better
The rail itself is fine to be left like that apart from rust considerations as mentioned above.
Sadly, the dent is big enough that it would fail a roadworthy.  So if this is an issue where you live, it would want to be fixed.  I had to pull all similar dents (much closer to the front end of the rail) out of mine to make sure it was going to pass Regency when I did my engine conversion.  We made a special tool that we could insert through the holes near the front to help with this.  That option would not be possible with the dent shown in your photo.  Too far back.  It it must be repaired, then you will be cutting metal out and putting straight stuff back.
Simple rule.  Chassis rails like that are not strong enough for chassis stands.  Too much point load on too thin a section of metal.  Even the doubled up seam that Duncan pointed out is not strong enough.  The only place designed to hold the car's weight is the jacking point under the sill.  This doesn't help, if you're jacking there you can't put a stand there too.  The only solution is to use stands that can fit under the lower inner pivots of the front suspension arms.  I had to grind the edges of the tops of my chassis stands to make them slim enough to fit in there.  Those points are hard enough and strong enough to hold the weight.  The only time this is no good is when you need to pull the lower arms off - then you can find an alternative way, probably involving the jacking points.
If you have to put chassis stands under the rails, then you need to use load spreaders, but this must be done safely, which is quite difficult.  Just putting lumps of steel/wood between the rail and the stand is not safe.
  • Like 1
I'm not in a location where the vehicle has to be inspected.
So my question is more like does this affect handling, alignment, or structural integrity in any way such that it would be better off fixed?
Or, is it just cosmetic?
And, for rust prevention, is that 3m stuff I linked the right idea or do you mean something else by undercarriage coating?
The rail is not bent.  The bottom of it has been pushed up which has pushed the sides out, but the position of the rail's centreline (left-right) is probably in exactly the same place as original and the height of the floor/straightness of the weld line along the rail/floor joints are probably not altered at all.  The rail might have slightly less strength against deformation (say in a frontal collision) than it used to, but that change would be quite small.  But this is the reason that they are defectable here in Australia with that sort of damage.  In reality, it is pretty much just cosmetic and nearly every other Skyline on the roads is in a much worse condition.
No.  That rubber stuff is not "rust proofing" in that you would not put it on bare metal.  it is meant to be put on top of properly prepared and rust-proofed steel, to provide an additional physical layer of protection over the chemical protection layer.  If you have damaged coating on that part of the rail and you want to protect it again, you will need to hit with some protective primer and/or underbody sealer/paint and only then consider the rubber shit.
Edited by GTSBoy
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
