Hi and welcome to :sau:
Do you have a multimeter? What happens when you touch the bulb terminals with the points? Do you get any voltage?
Have they ever worked?
Can you unplug all except the 3rd light to test?
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888330
19 hours ago, admS15 said:
At a guess, im going to say the switch at the brake pedal.
Question... never had this issue before to I noticed that when I push the brake the brake switch disengages... quickest way to find out if the circuits working? Multimeter? I brought a test light but the damn thing doesnt work
Thanks too for your help
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888399
3 hours ago, rjmparker said:
Right shi# f#*k... I have power at the switch but no power at the fuse box???!
Elp please
Sure you have the right fuse? 15amp one in the middle? With the key on you have no power either side of the fuseholder (one probe to earth and the other testing each side one at a time)? Tried a new fuse just to be sure? You have power at the switch but does the switch work as it should (circuit completed when brake pedal leaves it)?
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888483
Fuse is right fuse... I'm going to recheak the circuit, this shits doing my head in, and car was running when I was testing the fuses
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888519
If you have power at the switch the fuses are probably fine. Concentrate on the switch - is it moving freely when you push the pedal down? You have power one side of the switch do you have power the other side when the pedal is depressed? If not adjust or replace the switch.
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888526
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
