Hey guys,
So I was cleaning my R34 GTR the other day and thought I'd do a check on all the lights and discovered that the rear registration light had one blown bulb. I think they're stock halogen ones and I've never bothered to check them as I rarely drive this at night. So replacing them is a must but this begs the question should I leave them stockish halogen yellow or upgrade to LED bright white?
I front lights are LED globes so are relatively brighter white (not a fan of HIDs) so rear LEDs would suit but I've seen a few cars with them on and it looks like a midnight disco ball which attracts a lot of attention and looks a bit flashy then again the stock lights on cars like the Mercs have LEDs on the rear but they look nice and more tame.
What do you guys think and what have you done on yours? Photos would be great.
Cheers,
Alex
Image result for r34 gtr licence plate lights
Related image
Edited by Robocop2310
Not halogen.  Just normal automotive incandescents.  Halogen bulbs are in headlights.
Old cars like ours should not have LED lights anywhere on the outside.  Looks cheap and nasty and wrong.  Warm white auto bulbs for parkers, number plates etc.  LEDs are good for brake lights if you can get ones that illuminate the housing properly (which is rare).  LEDs for indicators need careful selection to make sure that they have suitable resistance to flash at the proper rate.  All in all, not worth the pain in the arse to try.  Globes work fine.
Awesome honest opinion mate thanks.
So just regular T1 whiter globes or just keep them the same do you think?
Which gloves do you have?
Cheers!
6 hours ago, GTSBoy said:
I have just normal T1s in the front and regular globes in the rear.
Thanks mate. I think I'll just replace the blown regular globe with the exact same one and leave it at that.
I went out to dinner this evening and saw a VW Golf GTI with LED rear licence plate lights and they looked awful.
Excuse you sir, Philips 4000K LEDs look just fine on my R32, although I do have HID projectors with OE Philips D2S bulbs.
Although they are quite expensive (~$25 a pair for T10) so not worth it unless they're on sale.
The issue of firing pattern has been brought up, so better to stick to standard incandescent bulbs. I only have the parkers and interior lights in LED.
Thanks mate totally agree.
So I went off to Supercheap and bought a pair of Philips T1 bulbs that are non LED but is a little brighter calked Diamond vision or something. Fitted them on and made the GTR’s rear light up line a Xmas tree. I went back to the stock yellow globes that I had laying around and it looked much better in my opinion.
Just shows just because something is popular or newer doesn’t mean it will suit everyone’s taste. Personally, I hate yellow as front and parker lights but they definitely suit the rear licence plate area.
4 hours ago, niZmO_Man said:
Which is why I like the Philips 'vision' T10, they aren't brighter than incandescent and have a good spread pattern (essentially emulating the incandescent). Essentially look like LEDs out of a 2005-ish Lexus.
Totally agree.
Good lesson learned from this exercise.
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
