8 hours ago, GDZ34R said:
Hi,
Anyone out there knows how much it’s gonna cost to upgrade base model stock gtr34 from 220kw to about 340kw?
Seeing you posted in the transmission/drivetrain section, I will assume you are only asking about upgrading these components to handle about 120kw more.
If you go above 400bhp you will have to swap the stock clutch assembly but, if you resist the urge to do 7000rpm launches, an upgraded clutch cover will grip a standard Nissan organic spinner to give nice drivability with good grip.
Really high power applications, or lots of abusive starts, will require something much more heavy-duty in the form of a multi-plated clutch. Triple-plate clutches can hang on really well, and have reasonable drive characteristics, rather than being on-off switches like some other multi-plate units but will be very stiff and horrible for daily drives.
I would set aside $2,000-$4,000 for something like Os Giken or HKS and a good mechanic (prices might be little higher as it’s been a long time since I looked into tranny upgrades so ring around).
Edited by Robocop2310
  • Like 1
https://www.sau.com.au/forums/topic/475306-upgrade-costs/#findComment-7890042
1 hour ago, iruvyouskyrine said:
Assuming the car is completely stock (which it isnt because its making 220kw but you gave us zero details) about $8k to have that much power reliably.
Does that take the gearbox into consideration?
https://www.sau.com.au/forums/topic/475306-upgrade-costs/#findComment-7890148
Here's the list of things you need to upgrade to make that much power.  Each one will cost $3k in PlayStation land.
Turbo
Turbo
ECU
Fuel system
Clutch
Gearbag
Diff (rear)
Diff (front)
Transfer case
Add in another couple of lots of $3k for rounding errors, etc.  Take off $3k if you decide to go single, but add it back on for the new exhaust stuff you need.  Sounds like ~$30k.
  • Haha 1
https://www.sau.com.au/forums/topic/475306-upgrade-costs/#findComment-7890151
Nah doing it wrong... you need to fit up a Samsonas sequential box, and an ECU such as an Emtron because other ECUs such as Haltech, MoTec, Link, Adaptronic, etc. are believe to be junk by many members here.
  • Like 1
https://www.sau.com.au/forums/topic/475306-upgrade-costs/#findComment-7890162
Honestly, the limit to how much you spend is endless if you have the cash.
If I were you, just upgrade the clutch and tansmission and if money perhaps get a good ecu if you don’t have one already - get it tuned and call it a day.
  • Like 1
https://www.sau.com.au/forums/topic/475306-upgrade-costs/#findComment-7890171
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
