Hi guys,
As the subject states, I've searched far and wide for this piece with no luck so if  you wanting to sell it or know where to source it from, please do let me know.
Many thanks,
Alex
Image result for r33 nismo gtr end caps
  • Like 1
https://www.sau.com.au/forums/topic/475589-wtb-nismo-end-caps-for-r33-gtr-wing/
I came across a piece of second hand ones but they asking for 50,000 Yen which is around $600 AUD if I'm correct. This is ridiculous!
https://page.auctions.yahoo.co.jp/jp/auction/x582723750
Pretty sure that's the going rate. I've been keeping an eye out for a second set, I've never seen a pair cheaper than $500.
Hence, i don't have a second pair. [emoji853]
That is crazy. I'm beginning to think the carbon fiber ones look better on my black GTR.
The cost is amazingly high. Unbelievable.
  • Like 1
Sorry to be the bearer of bad news. On the flip-side, if you find two sets let me know. [emoji16]
2 minutes ago, Steve85 said:
Sorry to be the bearer of bad news. On the flip-side, if you find two sets let me know. emoji16.png
Lol! I heard Nissan is bringing back parts for older cars in its latest catalogue so hopefully we can source these in the future for $100-$200 as they ought to be worth!
Where did you get you set, again?
I paid 57k for my set... lol
They were on the car. But I'm trawling yahoo japan for a set.
7 hours ago, GTR-N1 said:
Yes. Pretty hard to find.
Mate, if this is genuine Nismo - it's even rarer than the other pair! Never even seen it.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
