You’re right, the turbo did sound whistley  on the drive up to the mapper and doesn’t sound half as bad now.
The turbo did over come the leak but at the cost of working harder. Surely it would have build boost differently to if the gasket wasn’t leaking? That’s the best thing about analogue gauges as you can observe fluctuations and trends, digital doesn’t really let you see that unless you are logging...
  • 1 month later...
So I got a pal of mine who’s mapped a few Emanage ultimates to plug his lap top into the Emanage to see if there was anything untoward or just to look at the map (it’s just numbers to me) .
I was a bit out off at the shock he was in as he said that it was retarded across the entire rev range, also, the afm was selected as a standard afm and not as a z32 one which I have, the injectors were also standard when they should have been selected as 440cc.
We took it out with his wide band stuffed up the exhaust ?
He said it was really rich, we got back to mine and he tested the lambda sensor, it was “flatlined” so that needs replacing.
The only thing that I can confirm is that the brown plug behind the drivers headlight does not lock the timing at 15 degrees when it’s unplugged but does lock the auto box in third as I asked him to measure it. So that is good for mapping on the dyno I guess.
So, I’m going to get a new sensor and ask him to have a crack at mapping it. Or at least ask him to take another look.
Will report back... ?
Just for reference its this brown plug ?
  • 1 month later...
Quick update..
So the car go’s to a show this weekend and I know driving without a decent map could be engine suicide but I’ve had the fuel curve looked at and have been assured that’s it’s safe and there’s so much timing pulled out of it that it won’t det so I’ll trundle down to the show.
Took it out this saterday just gone to make sure everything is just so and ended up forgetting that it shouldn’t be thrashed until it’s been looked at properly and gave it the full biscuit... to my surprise it took off like hell in the night, it felt like it did previously, like before I lost the 58hp the only thing I’ve done recently is stop the re circ from the cam covers to the intake and blank off the lines from the plenum to carbon canister (now gone). I’m not complaining but I’d like to know what the hell is going on still, maybe the maf needs a clean? It is third hand so I may try that.... I’m getting it totally looked at early next month, the entire shooting match mechanically and ECU side by somebody that is very familiar with the emu and can spanner as well....
Will report back...
Edited by paulzy123
Spelling
  • 1 month later...
Hi,
The problem is fixed, I took it to a mate of mine that mapped his own car on the Emanage ultimate. He spent a good long time looking at the wiring. The injector earth wire had a dry joint in the pin in the loom connector and eventually snapped when we went to road map it so that got a new soldered lug. The lambda sensor was goosed so that got replaced. The SAFC 2 I was using to monitor knock still had a map on it and was wired in series with the Emanage wiring which was causing issues so the AFM side of it got removed, the AFM (z32) was spiking at 3.8 volts then dropping to 2.8volts straight after which was also causing problems so he “clamped the voltage?” Apparently it’s not to be used as a permanent fix it’s till I buy another AFM. We spent a couple of hours driving around and doing pulls while he sat on an ancient laptop typing and clicking away saying, “try that” and “do that again” until he turned to me and said right let’s turn the boost up.
At 18 psi it felt immense and it really was quick enough but he said I could go more so I did but in the end I settled at 19psi as upping it more didn’t seem to feel any quicker. All in all I was on the road around four hours and in his garage at least a day ?
Its quite quick now, well for an auto.
Well, that concludes my thread, thanks for all your advice and help ?
Cheers
Paul
  • Like 4
All's well that ends well. One lesson to be learned is that its very hard to guarantee  a good tune. The tuner might be over -rated, or a shop with a good reputation may hand the job to an employee who is not up to par (although one would like to think that such a person would have their work checked). One thing is for sure a good tune takes time and money!
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
