You’re right, the turbo did sound whistley  on the drive up to the mapper and doesn’t sound half as bad now.
The turbo did over come the leak but at the cost of working harder. Surely it would have build boost differently to if the gasket wasn’t leaking? That’s the best thing about analogue gauges as you can observe fluctuations and trends, digital doesn’t really let you see that unless you are logging...
  • 1 month later...
So I got a pal of mine who’s mapped a few Emanage ultimates to plug his lap top into the Emanage to see if there was anything untoward or just to look at the map (it’s just numbers to me) .
I was a bit out off at the shock he was in as he said that it was retarded across the entire rev range, also, the afm was selected as a standard afm and not as a z32 one which I have, the injectors were also standard when they should have been selected as 440cc.
We took it out with his wide band stuffed up the exhaust ?
He said it was really rich, we got back to mine and he tested the lambda sensor, it was “flatlined” so that needs replacing.
The only thing that I can confirm is that the brown plug behind the drivers headlight does not lock the timing at 15 degrees when it’s unplugged but does lock the auto box in third as I asked him to measure it. So that is good for mapping on the dyno I guess.
So, I’m going to get a new sensor and ask him to have a crack at mapping it. Or at least ask him to take another look.
Will report back... ?
Just for reference its this brown plug ?
  • 1 month later...
Quick update..
So the car go’s to a show this weekend and I know driving without a decent map could be engine suicide but I’ve had the fuel curve looked at and have been assured that’s it’s safe and there’s so much timing pulled out of it that it won’t det so I’ll trundle down to the show.
Took it out this saterday just gone to make sure everything is just so and ended up forgetting that it shouldn’t be thrashed until it’s been looked at properly and gave it the full biscuit... to my surprise it took off like hell in the night, it felt like it did previously, like before I lost the 58hp the only thing I’ve done recently is stop the re circ from the cam covers to the intake and blank off the lines from the plenum to carbon canister (now gone). I’m not complaining but I’d like to know what the hell is going on still, maybe the maf needs a clean? It is third hand so I may try that.... I’m getting it totally looked at early next month, the entire shooting match mechanically and ECU side by somebody that is very familiar with the emu and can spanner as well....
Will report back...
Edited by paulzy123
Spelling
  • 1 month later...
Hi,
The problem is fixed, I took it to a mate of mine that mapped his own car on the Emanage ultimate. He spent a good long time looking at the wiring. The injector earth wire had a dry joint in the pin in the loom connector and eventually snapped when we went to road map it so that got a new soldered lug. The lambda sensor was goosed so that got replaced. The SAFC 2 I was using to monitor knock still had a map on it and was wired in series with the Emanage wiring which was causing issues so the AFM side of it got removed, the AFM (z32) was spiking at 3.8 volts then dropping to 2.8volts straight after which was also causing problems so he “clamped the voltage?” Apparently it’s not to be used as a permanent fix it’s till I buy another AFM. We spent a couple of hours driving around and doing pulls while he sat on an ancient laptop typing and clicking away saying, “try that” and “do that again” until he turned to me and said right let’s turn the boost up.
At 18 psi it felt immense and it really was quick enough but he said I could go more so I did but in the end I settled at 19psi as upping it more didn’t seem to feel any quicker. All in all I was on the road around four hours and in his garage at least a day ?
Its quite quick now, well for an auto.
Well, that concludes my thread, thanks for all your advice and help ?
Cheers
Paul
  • Like 4
All's well that ends well. One lesson to be learned is that its very hard to guarantee  a good tune. The tuner might be over -rated, or a shop with a good reputation may hand the job to an employee who is not up to par (although one would like to think that such a person would have their work checked). One thing is for sure a good tune takes time and money!
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
