  • 3 weeks later...
hey, i've been on here for a while now but haven't put up anything about my car yet so here it is!
Mods are:
18x8 and 18x9.5" starcorp racing impul wheels
JIC front and KYB rear adjustable coilovers
new discs all round with EBC green stuff pads
front strut brace
Front mount
3" turbo back exhaust with split dump pipe and high flow cat,
k&n pod filter
R33 turbo on 13psi
turbotech adjustable boost controller
bosch 040 fuel pump
Haltech E6K ECU
And a stereo that i dont want to post up here.
plans for the future:
new front bumper (most likely GTR style)
highflow the turbo
Buy bigger injectors
adjustable camber and caster arms/rods
1.5 or 2 way diff (haven't decided yet)
new coilovers
fabricate a mdf/fibreglass boot setup for the stereo
buy an interior re-trim kit in dark grey and sandy/tan color
and then drive the thing once its all done pretty much!
  • 4 weeks later...
Hey guys,
Some of you will know me/ my car as the Red 66 mustang that used to get around on friday nights.
I now own a 93 GTR, and love it to bits... So many bits my pistons arnt in one peice any more.
Shall be out and about soon as the engine is a rebuild in progress.
Still got the stang and love it, but its so hard to drive after driving the GTR.
However i still shake after every race in the mustang even though its 1/4 mile pass is high 15's the rush is bigger than the GTR.
  • 1 month later...
Hey i'm new here, just thought i'd post up my new car. only had it about 6 weeks now but need to get it over dickson before i can do any mods to it apart from what it came with.
it's a 1992 R32 GTST with a 3 inch cat back (i think its 3 inch) exhaust, adjustable coil overs, pod filter and momo steering wheel. also has panasonic dvd fold out screen.
plans are to finish off the stereo with a 12 inch sub and amp the speakers, 19 inch wheels, wind the suspension down, then later a GTR front bar and bonnet with a front mount in there.
Yeah, dont go putting a GTR V-spec bar on it... I dont want people to think that we have the same cars ;)
Nice ride though, if you need advice or tips on modding, maintenance or rego, I can help... Ive been through it all. :P
Hey
im new here 2
I dont go to this site much but here goes
I got a 95 R33 GTS T not much done
standard motor
just bigger turbo t3/t4
exhaust full 3 inch in 4 inch tip from the turbo
Hks pod filter and blow off vavle
on 19s running 10 psi
Front and rear sway bars
plans probley engine change to rb26 i wanna runn 18 - 20 psi so new computer, bigger injectors, forged internals, boost controller, big front mount, bodykit and paint
any suggestions welcome
post-44589-1197011117_thumb.jpgpost-44589-1197011111_thumb.jpgpost-44589-1197011104_thumb.jpg
Edited by R33Gtst Driver
  • 2 months later...
Hey guys,
My name is Glen and I am a proud owner of a Bayside Blue 2001 R34 GT-R V-Spec II.
Everything standard except:
Nismo Dash
Blitz Nur exhaust (Cat Back)
Bridgestone Potenza RE-01R tyres measuring 245/40 R18.
Blue Eyelids.
Plans:
To lower the weight of my vehicle as much as possible and to modify my GT-R with total balance in mind. So handling, braking, response and power will all be improved, and not to just go crazy on any one aspect of the car. Similar to SUPER GT & MINE's...
If all else fails, then I will just wait for R35 GT-R! :)
Edited by xanavinismo
Very, very nice! I have seen the RX-7 around belco a few times but not the GTR. It must be hard to decide which car to drive when you leave the house.
Hope to see you out and about, maybe even bring it out on a friday night or to some of our upcoming events?
Hi
Heres My R32 GTS-T
Full GTR Body Kit, FMIC, Lowered - King Springs, 18" Speeddy Wheels, Pod Filter, Turbosmart Duel Boost, 3" Exhaust, Walbro 255lph Fuel Pump, Cusco Strut Bar, Momo Race Steering wheel, Greddy Turbo Timer, Boost Gauge, Blue Gear/ Hand Break Boots, Apexi AFC, Factory Sunroof and also a chiped ECU.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
