The time has come for me to sell my 1994 R32 GTR V-SPEC.
Year: 1994
Make: Nissan
Model: Skyline R32 GTR V-SPEC
Colour: KL0 Spark Silver Metallic
Odometer: 55xxx kms
Price: 50,000 AUD
This is a February 1994 V-SPEC, the last of the V-SPEC 1s before the V-SPEC 2 was introduced in March 1994 (V-SPEC 1 #1352 of 1396).
Reason for sale – I bought this car 7 years ago, before marriage and children. Unfortunately, as much as I’d love to keep it as a future collectable, it just doesn’t work as a second family car. In my time of ownership I think I would have done less than 6,000kms.
Recent service – by August 2018 the car had sat for 18 months while I built a new house. I took it to Galvsport here in Perth for a full service. In addition to the usual engine oil / gearbox oil / sparkplugs, I had the injectors cleaned, a bunch of fuel hose / wastegate hose / steering hose replaced and dump pipe re-wrapped. The entire rear subframe was also removed so that all subframe bushes could be replaced along with gearbox crossmember bushes, wheel alignment done, etc. New Optima D34 dry cell battery was put in the car last month.
Modification list, some done by me and some done by prior owners:
Engine:
R34 GT-R V-SPEC2 engine
VIPEC ECU, runs on E85
Garrett GT35R turbo
6Boost manifold
50mm Turbosmart external wastegate with screamer pipe. Plumb back pipe included.
HKS 272 cams
Adjustable cam gears
LS2 coil pack conversion
Deautschwerks 1200cc injectors
Sard fuel rail
Sard fuel pressure regulator
Galvsport custom catch can
Battery relocated to the boot
Larger capacity sump (believe its Hi Octane)
N1 oil pump
Nismo 1.5 way front diff
Trust oil filter relocation kit with Mocal oil cooler
Custom intake and heatwrapped dump/front pipes
Warlbro fuel pump with direct power source
Braided oil and water lines
HKS intercooler
HKS Silent Hi-Power exhaust
Exedy twin plate clutch and light weight flywheel
Tuned on E85 to 610rwhp @ 22psi by Sean at All Star Garage.
Wheels, Suspension and Brakes:
ETS PRO ATTESSA controller
Genuine Work Meister S1 3P 18x10.5 (gloss black with chrome rivets)
Federal RSR tyres
Diff reconditioned by Greg “Dalspec”. Breakaway torque increased. Backlash reset
MCA X-R coilovers
Front Cusco tension rods
Front UAS pivoting adjustable camber arms
Unknown brand adjustable rear camber arms
HICAS removed and lock bar installed
Whiteline front & rear swaybars
Strut bars front and rear (Cusco)
Interior:
Nismo 260kph dash
ATTESSA controller along with 2WD/4WD switch
Autowatch alarm system with inbuilt turbo timer
Just replaced the c-pillar trims with brand new ones
No tears or rips on the seats
Body:
N1 vents
N1 boot lip (not installed but included in sale)
N1 side skirts
N1 rear spats
6000k HIDs
Air con was removed at some point but have all the parts to go back in. Any standard parts that I have removed from the car have been kept and will go with it (e.g. the standard single DIN 3-gauge in dash cluster, heater / aircon controller, etc.).
Asking price is $50,000.
Please no time wasters or test pilots. There will be no joy rides. Test drives will only be for the genuinely interested and at my discretion. Please have your finances sorted before you view the car. Viewing won’t be at the car’s storage location but happy to meet at a mutually suitable location in the Subiaco area.
You can reach me on 0402 141 438. I am located in Perth, WA.
Cheers
James
  • Like 3
https://www.sau.com.au/forums/topic/476185-fs-1994-r32-gtr-vspec/
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
