Hi Guys,
Doing a bit of a garage clean out and have a few things for sale.
Will probably add stuff as i go along and find more, but here is what i have at the moment:
Bosch Motorsport top feed 1000cc injectors. Used only for 5000kms with 98  $500
R32 GTR OEM BOV return pipe (used)  $150
R32 GTR OEM front sway bar (used)  $100
R32 GTR OEM aircon ducting (used). Every bit of plastic ducting from under the carpet and dash, except the one that goes to the drivers side vent  $50
R32 GTR OEM Twin Turbo pipe (used)  $100
R32 GTR OEM coil packs (used) $50
Ruzic II 4WD controller (used) $500
R32 carbon boot lid with carbon N1 lip and genuine R35 GTR badge. Boot lid has crazing all through the clear/resin, N1 lip is perfect, so is the badge. $500
R32 GTR series 2 textured center console surround in mint condition with lighter (used) $500
R32 GTR series 2 textured center console surround with a crack at the very bottom next to gear boot, and one broken tab at the very top $100
Sparco Sprint V fixed back seats. Pair, no rails. Very little use, some marks from storage but no tears. $500
Open to offers within reason.
Items are located just south of Wollongong.
Willing to post smaller items at buyers expense, larger items like ducting, seats and boot lid prefer pick up.
There will be more to come as I get through everything.
I will upload pics when I get a chance.
https://www.sau.com.au/forums/topic/476257-gtr-bits-and-pieces/
Also have:
Haltech I/O 12 Channel Box A only, no lead (used) $300
Haltech Can Hub Mini with 2 cables (used) $100
Haltech O2 sensor with new weld on bung, still in good condition (used) $100
R32 GTR OEM map sensor (used) $50
R32 GTR OEM Alternator (used) $100
R32 GTR OES CAS Bracket (used) $50
7 hours ago, horus83 said:
Hi Mate,
Do you still have the
Center console surround, Can you send me a pic?
I still have both. Which one were you after, the mint or cracked one?
16 hours ago, horus83 said:
If you can PM both ill decide which one? I am assuming it is the grey texture finish ones?
Yes they are both the series 2 grey textured finish ones. PM sent.
Some pics.
Ducting, Sway bar, oem map sensor, Haltech O2 sensor, Haltech I/O Expander Box A, oem cas bracket, Haltech Can Hub Mini, Injectors, Ruzic II 4WD Controller, Mint series 2 textured stereo/shifter surround.
More to come.
  • 3 weeks later...
  • 1 month later...
1 minute ago, theskidmasta said:
i know you prefer pick up,  but if you can calculate shipping to socal usa i can take the boot lid off of your hands
With the size of this thing shipping it to the states would not be worth while.
You would be better off sourcing one locally.
i cant find a decent one in the US for less than 1k AUD
Well JACKA87 is supposed to be picking it up this friday.
If he doesn't pick it up, I'll look into the shipping costs, but i know it wont be cheap and the total cost will be up around that 1k figure im pretty sure.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
