Nissan has add 24 more pieces to the Heritage program.
Linky Here
Nismo link in Japanese. This works better on my phone where it will translate.
The highlights in my mind are new blocks, heads and R32 body panels.
I wonder if they would be making any changes to the metallurgy.
  • Like 3
https://www.sau.com.au/forums/topic/476475-nissan-adds-to-the-heritage-program/
My expectation is that aluminium front end panels would be in high demand.  Any GTR that has suffered a front end collision has trashed the bonnet and or guards.  These are usually scrounged off another car, not repaired.  Must be in dwindling supply nowadays.
I would think there'd be a big interest in seats and door trims.  Anyone buying the bits that are already available for a restoration project would almost certainly jump on the most visible parts.  Door glass (to get rid of scratches) would be a possibility, along with the various electrical components in the doors (window switches, power window boxes).
Some of these things may still be around in some numbers in NOS, but I'd expect a lot to be running out.
Unfortunately I don't see the front panels listed. Only the bumpers and rear quarters. I hope the fronts will be added.
I haven't needed to look up windows.
Are they that hard to get?
Didn't think the 05U blocks ever went out of production. Still always been obtainable. New 05U casting type maybe ?
We need to find some more info on this.
I didn't say "the" front panel.  I just said that front panels should be in demand, in response to previous poster's "see what they produce next".
As to block metallurgy......I would not hold my breath.  It's not as if the cast material they were using had any problems.  The design, on the other hand, is where the block is weak, and the design is what they really won't change.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
