What's going on guys? I have a 1991 GTR and just got it. Its currently overheating and when it does the oil temps get up there too.
I tried to search but didn't see the issue i was having. I have a theory on what it might be but I'm going to wait and chime in when you gurus reply.
Hint: thinking its the water pump because oil temp and coolant temp go up at the same time, meaning its not circulating as it should. Gets so hot it starts to boil.
https://www.sau.com.au/forums/topic/476599-1991-gt-r-overheating/
Well firstly, congrats on picking up the new car! 91 is an unusual year, was it Australian delivered?
As for the overheating, unfortunately there are a lot of potential reasons and not enough info to really guess.
If it overheats when stationary (unusual on these) it suggests some problem with the viscous coupling on the fan, these wear out but generally seize to be on all the time
If it overheats based on time or load when driving there are a lot of things to check and you may want a mechanic to do them
-air lock somewhere from coolant not being bled properly. rebleed the system including having the heater on full and opening the bleed on the intake manifold near the injectors, and using some sort of bleeding funnel. If the car had been serviced by someone who wasn't careful this is the most likely issue.
-thermostat not opening, this will make it overheat pretty quickly but is an easy fix
-leak in the system. run a pressure test and make sure there is no issue. another symptom here will be coolant loss. Leak could be in the radiator, hoses, heater core, radiator cap not holding pressure. Potentially and expensively but unlikely, it could also be a head gasket or block crack.
The water pump itself can't fail to pump as it is belt driven from the fan/water pump/alternator belt. That should be obvious if missing....when water pumps fail they leak from the seals
Oil temp goes up because water cooling system isn't working properly. First I'd flush the system (take out radiator, flush that, then flush the block). Also check your clutch fan, it should spin with resistance (engine off), and you should hear it turn off after a bit when you first start the car cold, and engage (go loud) when it gets hot.
Appreciate the help guys.
Pulled out the thermostat and tested it. It appeared to be working, found a replacement at a parts store off a 95 300zx so minus well change that out since I was already in there.
Next up is the clutch fan. I remember spinning it but it didn't seem to put up much resistance, trying to find one locally (I'm located in Texas) I looked around and read a 1991 Pathfinder clutch fan works. Do we know if this is accurate?
Ahh that will make it a bit trickier.
Not sure about the pathfinder option, here we generally use rb30 skyline or patrol as the cheap but compatible replacement.  The good news is it only has to fit physically so if you take yours off you should be able to compare.
Did you flush it out thoroughly, rebleed everything properly and do a leak test? Chasing and changing parts is doing the hard things first.
Good news guys, I was able to locate a 1995 300zx thermostat. Although it is a bit shorter from the top the rest of it is identical to the stock nissan one. Ill attach a picture just for a reference. 20190413_202729.thumb.jpg.f0b3b21148abe935035513a7219bf585.jpg
When I pulled the old one out, it read Nissan on the top. So it may have never been changed, either way I needed a new one.
Cleaned up the clutch fan as well with some WD-40 on the little coil part and a wire brush. That gave it back some resistance when I spin it. Used this video as a reference:
Anywho, used the manual and refilled the coolant, and topped it off. Drove around for about 40 minutes with some spirited driving, freeway, and put myself in some stop and go. Temp stayed at halfway and my oil temp was good too. Im pretty sure its fixed.
Thank you guys for the help.
If you are in Texas, may consider getting a new radiator if you are still running on factory one.  Both Koyo and Mishimoto offer reasonably priced replacements.
As for the fan clutch, if I recall Infiniti Q45's can work but not exact.  There was an discussion about interchangeability on Rivsu's old forum before they went out of business.  From what I can remember, almost all the late 80s and early 90s Nissan clutch fans share the same bolt pattern but vary a few mm in height, and unfortunately there is not one with the exact height as R32.
Edit:
Here is an old picture I found, not exactly sure which car this came from, could be a Z32.  So the unknown new fan clutch is the exact same height as R32, but somehow the base is 2mm thicker and so the nuts could not be tightened through all the threads.
Edited by TXSquirrel
Did some driving around and its been a couple of days with no overheating. Drove it to work today and noticed this happening.
I was parked here but I usually notice it at lights on stop n go traffic, etc...
What were looking at is when I press the brake in the needle in both gauges will rise, when i let it go they will drop. Do you guys know why that is?
Looks like she's l running a bit hot (noting it may well have been a hot day there...)
That movement in the gauges must be a minor electrical issue.....either a bad (common) earth, or gauge power circuit, or even battery terminals. I haven't seen it before but I wouldn't be worried.  Does the volt gauge work (and, does it move when you put your foot on the brake?)
Yeah its a little hotter today here than it has been. My volt meter does work and it reads just above 12 volts. It doesn't move when I press the break.
I believe it when you say it might be a bad ground or wiring issue. Noticed it flinches very little with the blinkers on as well. Car needs a good scrubbing down in that engine bay and grounds redone.
I have the ground (negative cable) from the engine to the negative battery terminal and about halfway to the battery is another grounding point (not grounded) Do you know where that goes too on the chassis?
That is very likely to be the issue if the main battery earth is only connected to the engine.  It should go to the chassis first just near the battery (above hicas pump if you still have it), just an m6 thread that you put a bolt in. Let me know if you can't find it, I'll try and get a pic although my setup is a little non standard.
BTW healthy alternator should be charging the battery at something around 13.8v so 12 is not right. Noting the standard gauge is hard to read properly.
If you have a multimeter check the voltage across the battery when the car is running.
Ill check the voltage when its running. Ill do that. Let me go look and see if i can see where the negative gets hooked up too.
I took the car on a spirited run and it overheated on me. Coolant was at the top line just under the Hot. Shut it off, let it cool and limped it home. I dont see any leaks but its so hot is boiling the coolant and spilled into the overflow tank.
Car was running good. Drove it Tuesday and friday with no issues. I wonder if me driving it hard is what gets it to overheat. When i drove it tuesday and friday i just cruised with some random little spurts but mainly cruised to and from location.
Im gonna invest in a radiator and currently my condenser fan doesn't work or isn't engaging/turning on. Is that just for AC? Could that be an issue as to why its overheating?
I appreciate your guys help.
I don't think I have seen my oil temp gauge gone up that high since I have owned mine, even after multiple pulls on the dyno.  I highly recommend a thorough coolant flush and a proper bleed (there is small bleed valve on the head near fuel rail).  Maybe throw in an oil change too, it's cheap insurance.
Yes as far as I know the condenser fan is only trigger by A/C.  You can wire it to run from a toggle switch to help cooling, but that still won't solve your core issue, plus your electric system doesn't appear to be 100%.  I Google a little more and the fan clutch I posted above is from Infiniti Q45, so feel free give that a try since it's only a $50 part from any local part store.
As for your electrical issue, other than sorting out the grounds, a new alternator is definitely helpful.  Circuit Sports offer a new direct OE replacement and they are reasonably priced.
  • Like 1
Alright, update time.
Went out and bought a fan clutch for a 1991 Z32, it was the same as the one for the infiniti Q45. Flushed the system and replaced the coolant by undoing both upper and lower hose and removed the radiator and cleaned it out with water from the fill and it trickled all the way to the lower.
I used this to flush the coolant and refill it I did NOT remove the block drain plug.
I did notice that part of the refill procedure for the coolant there is a step that says to check the lower radiator hose to see if warm coolant is passing through. When my upper hose is warm, the coolant in the lower hose is not.
It also states for you to check the thermostat injection valve (step 7, on the service manual screen shot in the thread above). What is that? The thermostat?
I also check my grounding point cleaned it up and bolted it down. Voltage and flickering on the gauges it gone gauge reads at the 14 volt mark and the Alternator is new, pushing out the required volts.
Also, I went out and got some fresh oil in the car. Read up everywhere and saw it takes 4.5 quarts of oil but not to be afraid to use 5. I used 5, 10w30 full synthetic Mobile 1.
Drove the car around again, coolant temp is good half way but once my oil temp gets to the halfway mark (referenced picture was the 1st time before I changed out the oil) that's when my coolant temp just starts climbing.
Waiting on payday, last thing I can think of that I haven't replaced is my radiator, after the radiator swap I'm out of options on what it is if that doesn't fix it.
Just thought of something...
When refilling the coolant and it ask to feel the lower hose and it doesn't feel warm when it should, it might be the new thermostat I bought is/went bad, or worked and stopped working.
I have bought parts from a parts store and having them fail a week later. It was a 300zx thermostat.
Hmmm sounds like you have all the basic maintenance covered.  I am sure you have checked them, but your fan, fan blades, and fan shrouds are all in good shape?  And you already replaced your water pump right?
I notice your oil pressure is looking a bit low, but that could be because your oil was running so hot and viscosity decreased.  Mine sits at ~4 during idle.  Hopefully other can chime in on this, and hopefully that's not a sign for a bad oil pump.  (However, oil pressure sender is known to go bad, could be as simple as that.)
As for the radiator hoses, the lower hose is supposed to be cooler than upper hose.  (I have a laser thermometer that I can measure the delta next time I take my car out.)  But are you talking about a big temperature difference between the upper and lower or the lower not warm at all?  If so then I am drawing a blank since you already flush your radiator...
Like you said, maybe try another thermostat.  It's been around 85°F here and a healthy factory radiator should be able to cope with that.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
