Less than 500km.
Removed due to excessive noise with full catless exhaust.
WARINING WILL ROBINSON
If you have a full catless exhaust this Tomei UEL header will make your exhaust as loud as balls.
$600.
Everything except the box and the gasket for the overpipe.
PICKUP ONLY from Holsworthy, 2173
  • Like 1
https://www.sau.com.au/forums/topic/477408-toyota-86-brz-tomei-uel-header/
Loud is good for 86 owners, that's all they can offer besides half of the ASOS catalogue and flat brim hats lol.
Cheap btw, good luck with the sale. Post it up on PoofBook groups, you'll sell it quicker!
Don't do failbook.
You would be surprised how a little NA 86 goes with about 200hpatw, it ain't no rocket ship, but it definitely isn't a slouch getting around town.
About the same as a stock turbo S15, only the 86 handles better.20190618_115301.thumb.jpg.33146d4469fabf37789f72e3a6a27d02.jpg
LOL, I had to google ASOS, and my cap bills are as curved as fark.
Buy my shit....
On 27/06/2019 at 12:18 AM, Iron Mike said:
Selling BRZ parts on a Skyline forum probably won't happen very quickly ?
No real rush, plus I believe this is a Euro forum now, apparently, or not, maybe......
1 hour ago, Dose Pipe Sutututu said:
It's a building forum, didn't you know?
Somehow we've saturated it with car talk.
Need to go back to our roots:
How's this puppy?
Mandrel bends, VTA, manually adjustable, hell, even a spare port for a wide band
  • Like 1
2 hours ago, Dose Pipe Sutututu said:
Wow, that is sex spec, even Queen Street Plumbing will get jealous. I hope it graces the PlumbingSalon magazine next edition
I was going for this look, I think I pulled it off well.........
LOL....Pulled it off well.........
$580
Do it.
Or...
May swap for old Japanese motorcycle.
Paint and plastics are not important.
Rego is not important, BUT (notice the big "but"), you must be the last registered owner.
Engine size not important.
A rolling frame with a engine will do, I'm going to pull it apart anyway.
  • 3 weeks later...
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
