For sale is a set of 370GT Enkei produced Nissan Skyline rims + tyres.
Asking price is $750 ONO.
Pretty clean condition with some minor rashes here and there as expected with its age.
Sizes:
Front - 19x8.5 +43
Rear - 19x9 +43
Tyres are still good with Kumho Ecsta LE Sport's wrapped around each rim.
Happy to ship interstate provided you organise it at your own cost.
Cheers, Chad.
https://www.sau.com.au/forums/topic/477647-v36370gt-parts/
Up for sale is my VQ37VHR 3.7L V6 Engine with its CD009 6 Speed Manual gearbox attached.
Asking price for the lot is $3500 ONO.
This motor has travelled a low total of 93,000km and was still operational before it was extracted from the vehicle. The motor has always been serviced at its recommended service intervals and a logbook that came with the vehicle can be provided for proof of service history. Videos and pictures of evidence of the engine operating before extraction can also be provided to you upon request. Attached are results from a compression test.
This motor has had a compression test performed and is ready to be dropped into another vehicle to start a new life in another comfortable chassis. This motor also comes with the entire wiring loom and ECU, subframe, hubs, LCA's, strut towers, Injen intakes and its slim washer bottle.
At $3500 AUD, this combo is priced to sell. Feel free to send me a text or give me a call to arrange a time for inspection and purchase at our workshop.
NOTE: Buyers from Sydney will get first dibs. I am happy to prepare the motor and gearbox for shipping if you are located elsewhere, however, shipping costs will be on you.
Contact Chad on 0450772796 if you are interested in inspections or purchase. Please do not contact Chad if you do not have cash on hand.
Cheers.
https://www.sau.com.au/forums/topic/477647-v36370gt-parts/#findComment-7909535
  • 4 weeks later...
On 7/28/2019 at 6:37 PM, chaaad said:
I want these gone!
If it helps mate, Possibly overpriced. In bris you can get a full set of 370z Akebono's including Rotors for $900.
https://www.sau.com.au/forums/topic/477647-v36370gt-parts/#findComment-7912856
On 8/19/2019 at 5:34 PM, chaaad said:
Brakes for $550
Engine for $1k
Gearbox for $1.1k
Wheels for $550
Or offer me! :)
How much for the Brakes with the Calipers and pads Shipped to bris?
curious as to the rotor condition.
https://www.sau.com.au/forums/topic/477647-v36370gt-parts/#findComment-7914538
I will take $550 for the calipers. I would not recommend running the rotors and pads as they are worn, so I won’t let them go in shit condition. Shipping is on the buyer, so you will have to contact a courier to organise freight.
https://www.sau.com.au/forums/topic/477647-v36370gt-parts/#findComment-7914546
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
