Hello,
So I bought a relatively stock R34 GTR and after 500kms (all was working fine) the engine just shutdown on the highway.
The engine is cranking but refuse to start again.
So in the correct order, I checked using the supplement service manual:
-no engine light at any moment
-fuel pump (I can hear it when I switch on the key and the fuel pipe gets hard)
-checked all the fuses next to the throttle pedal and also in the engine bay
-self diagnostic give me error 55 (so no malfunction)
-I have 12V to the coil ignition on the power pin of this coil
-I don't have an oscilloscope however when cranking the engine I must see like 0.06V to 0.09V on the command of the coil ignition using a multimeter but I got 0v on each command of the spark plug
-wiring of the ignition coil is okay (continuity test)
-There was an aftermarket ignition control box (adic siccle advanced ignition control) connected to the ECM; so I removed it however after doing so I got error 20 ? (the orignal hairness seems to be intact !)
-I open the ECM but didn't find anything bad (bad soldering, blow components ...)
So this investigation supposed that the ECM is not working properly ?!
Question :
-what is error code 20 ?
-if the ECM is working fine; what are the causes that avoid it to command the ignition coils ?
There is also an aftermarket alarm I normally desarm it (using the key fob) code alarm PF7600 I don't think there is a relation to my problem but I mention this.
Thanks for any hint
https://www.sau.com.au/forums/topic/477754-r34-gtr-no-sparks/
There is no ECU code 20 for GTRs, unless they've added some secret sauce to the R34 that wasn't in the earlier ones. (although 21 is the ignition circuit.....you sure you got 20 and not 21?)
A multimeter cannot be substituted for an oscilloscope unless you're looking for a steady voltage. They are not fast enough to see brief signals.
I would say the ADIC is responsible. You'd best base your research around it.
Edited by GTSBoy
My GTR was build in 08/1999
Well I'm sure it's 20; two long blink followed by a pause of like 5 seconds and then again 2 long blink.
Yes I know for the multimeter but that's only what I've got for the moment...but I should see at least some variation on the voltage which is not the case; I measured 0V continuously. I will borrow a scope and try again.
I don't get any information on the ADIC :/
Like I said before removing it I got 55 and after removing it I got 20
Can you elaborate choyda ?
Thanks for the help I really appreciated it
Edited by bigboss59400
CAS is the thing on the end of the camshaft that tells the ecu when to fire the plugs and injectors. If you are going to take it off and haven't got a timing light mark it carefully so you that if its ok you can put it back in exactly the same position. Turn it by hand to feel if the bearings are stuffed. With the key on turn it and see if it fires the plugs (maybe pull one out and look for a spark (making sure it has a good earth). If it does look inside the cas and the end of the cam shaft to see if the drive has been damaged.
21 minutes ago, GTSBoy said:
Yes, because there are no codes ending in zero.....
I didn't noticed that thanks!
22 minutes ago, GTSBoy said:
And ref the root cause - probably ground the drive off the end of the cam, by the looks of all them chips in there.
Okay I will remove sensor and see
On 7/15/2019 at 3:20 AM, bigboss59400 said:
Just for information I found some on aliexpress
They look OEM I will buy and see
Thanks for all
There are basically two - one with plastic cap like yours Hitachi 2371 5L 300
The other one is a Mitsubishi with metal cap 2371 02U11 which will not work.
Have a look at the end of the camshaft and see if the drive appears to be damaged.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
