Sard 650cc top feed injectors, sard fuel rail and sard fuel reg, came off my rb25 neo engine, great condition, only removed due to upgrade, all genuine sard, $250..
NEW plazmaman fuel rail for a rb25 neo, cost $295 selling $200..
NEW zeitronix wideband afr and datalogger with gauge (blue) cost $350 selling $270..
Rb25 neo cam covers all polished, will come with new proflow fittings, $200..
All parts are located in Geelong victoria but can post anywhere at buyers expence if needed..
**more parts to be listed soon**Screenshot_20190721-173104_Gallery.jpegScreenshot_20190721-173326_Gallery.jpegScreenshot_20190721-173442_Gallery.jpegScreenshot_20190721-173414_Gallery.jpegScreenshot_20190721-173220_Gallery.jpeg
https://www.sau.com.au/forums/topic/477861-bits-and-pieces/
Hi, I have a brand new HKS kansai roll cage for a R34 coupe, still able to have rear seat in, has side intrusion bars, all still in original packaging, no need to wait to get made and then sent over from Japan, located in Geelong victoria but can post anywhere at buyers expence if needed.
$1400..
https://www.sau.com.au/forums/topic/477861-bits-and-pieces/#findComment-7911676
Hi, I have a HKS kansai roll cage for the R34 coupe, has side intrusion bars and you can still fit rear seat, No need to wait to have it made then sent from Japan with all the extra cost.. located in Geelong victoria but can post anywhere at buyers expence if needed
https://www.sau.com.au/forums/topic/477861-bits-and-pieces/#findComment-7911889
$1400.. price is firm..Screenshot_20190724-164644_Chrome.thumb.jpeg.ae0949faec99acc45ed8c9e467bee257.jpeg
.Screenshot_20190726-191818_Gmail.jpegScreenshot_20190726-191757_Gmail.jpegScreenshot_20190726-191836_Gmail.jpeg
https://www.sau.com.au/forums/topic/477861-bits-and-pieces/#findComment-7911890
Hi, just a eoi and will sell soon just want to put feelers out there to see if much interest, I have a like new set of rays gt4 nismo omori edition wheels in 18×9 with a 22 offset, all 4 wheels are in perfect like new condition, probably only done 500km on them, wrapped in federal RS-RR tyres, 265/35 rears and 245/40 fronts, I'd be wanting no less than $3800, they are located in Geelong victoria but can post anywhere at buyers expence 20190727_145522.jpeg20190727_145508.jpeg20190727_145456.jpeg20190727_122135.jpeg
https://www.sau.com.au/forums/topic/477861-bits-and-pieces/#findComment-7912004
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
