rackmount bushes, nismo vs poly vs oem
Yeah well my guess is they have done all the development on USDM models and that may not apply the same for JDM and ADM. My 2016 shifts up automatically in manual mode, which they describe as being the sign of a 2018.5 or later.
There was posted some where on here recently, about how to change resistors/open some connections/close other connections, and it can alter the speed output, if the gearbox is sending the signal to dash, and then dash to ecu.
Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore. -
The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
