15 hours ago, Hella_GTR said:
Deposit placed! Stoked! Thanks all for helping me in this competitive bncr33 market here in Japan! I'll update you with my own photos in the near future!
YES! Well done. I don't think you will be disappointing, that car looked amazing. Keep us up to date... I'd love to hear the full story if you do go ahead. :D
  • Like 1
48 minutes ago, BakemonoRicer said:
Hella you have the same illuminated skyline rear garnish as me lol
So at first I was confused as I use the word garnishes for food lol. So I Google'd it and does that mean our rear skyline plate illuminates when the lights are on? It looks like it's a very rare factory option. That is actually really awesome and would be an unexpected treat! Can you tell by the look of that panel? Either way now I'm more stoked to see this car in person once it gets shipped. It's all paid for now just doing the paper work here from a Kanji plate to a Y license plate is quite cumbersome. The whole process takes a couple weeks. I'm debating now to leave it alone or get some black or matte black nismo lmgt4 wheels and some suspension ?
Edited by Hella_GTR
  • Haha 1
Most of the point of the VSpec is the suspension and A-LSD. Not much else to write home about. If you do go with coilovers I would suggest the Ohlins Road & Track.
Yo Josh,
Totally know what you mean.  I'm leaning towards the Ohlins with the rubber top hat bushings (don't know if you read into my R34 JRZ issues on this forum), but there's only one distributor here in Japan.  I need to check availability.  The spring rates area  bit soft for my liking but maybe they can customize them.  Japanese dampers are easier to get here and have more support (obviously), like the HKS Hypermax.  I know they probably suck on the road though. But finding support for my JRZ's from the Netherlands here was really difficult and time consuming.  If i didn't have a horrible experience last time, I'd get JRZ's again as they're just amazing when working properly.
16 minutes ago, Hella_GTR said:
Yo Josh,
If you follow Aki's blog at all Ohlins are definitely the way to go. They are quite stiff already, there is more to suspension than raw spring rate. For bumpy roads excessively high spring rates will cause the car to have worse characteristics. Nismo uses Ohlins DFVs for their N-Attack Pack and CRS package so I think the dampers + springs are well validated.
Yeah I'm fully aware there's more to suspension than spring rates.  Have you ever tried JRZ's RS two-ways or motorsport line?  They're on another level than ohlins, but they also cost more. They're also rebound and compression adjustable.  The 3-ways are awesome too but get a bit complicated to set up.  The beauty with good dampers is you can use stiff spring rates but still have a comfortable ride.  Poorer quality dampers can't do this so they use softer rates or just give you a harsher ride.  I ran ohlins in my BRZ several years ago and they couldn't compete with JRZ at all but I believe that was before Ohlins implemented their DFV technology.  8k springs just seem a bit soft to me for occasional track use. But ohlins are probably good for bang for the buck.  I hear Aragosta's are similar to JRZ since one of the JRZ founders split off from JRZ and made Arogosta.  I don't know why I'm advocating for JRZ when their top hats made a ton of noise on my r34.  They did eventually agree to make new top hats for me but it was too late by then.
http://www.jrzsuspension.com/rs-two-sport.html
Let me check out this Aki's blog page though.  This is the first time I've heard of this.
Edited by Hella_GTR
8 minutes ago, joshuaho96 said:
r33gt-r.com is his blog. A lot of interesting background on the R33, various mods, etc. He's currently a lawyer at Nissan so he's slowed down on the posts but it's been pretty interesting through the years.
Oh wow I did run into his blog in my google search about wheels for my r33.  Ok now I see his entire blog.  uggh I want those Nismo lmgt4 wheels but $$$.  Thanks for sharing man.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
