Your Brakelever looks like this?IMG_2980.thumb.JPG.d3e815b1c840e5f765c0aa3981d45154.JPG
Time for an update!
you need a sheet of smooth (automotive) leather, some Needles and waxed Thread. I get this from Aliexpress for less than 3$.
First pull out the Metal Ring a little bit then cut the stitches
And , surprise,  the original isn`t genuine Leather!
Took the original as a pattern for the new .
Attention !!!! It isn`t a square.
To get a perfect fit , cut 2mm narrower.
Now do the punctures
3mm from the edge and 5mm wideIMG_2994.thumb.JPG.d8430794b7699bb92612fcca4d114e2d.JPG
You start like this. The thread has to be 4-5 times longer than the leather!!!
To make it easier use a tube, keep attention that the cross of the tread , up and down, are all in the same way
Now you can place the Leather to the Lever
and then pull the seam tight do this with a crochet hook
You can`t do this at once. Make 2-3 repeats!
Keep an eye that the alignment is correct and the holes are at the same level.
At the End .....the tricky Part.
You have to put the Leather under the rabbet and fix it with the metal ring.
The Leather has to be long enough but then it has a lot of wrinkles, is it to short it won`t be fixed
Tricky.
But in the End  I´m very satisfied.
A lot better than the old imitation Leather.
I hope this is helpful for some!
Edited by Fastlane
  • Like 9
https://www.sau.com.au/forums/topic/478576-brake-lever-leather-renewal-diy/
Small Update !
To avoid the Problem to get the Leather under the rabbet it is possible a good idea to choose a smaller Pre-cut.
I will test this when I get my red Thread!Zuschnitt.thumb.jpg.77c8abede85d2c8d84d9b254f3c6a127.jpg
In total the cut is 6mm smaller  this will help a lot
  • Thanks 1
  • 1 month later...
to make the Precut 3mm smaller is too much , but it is depending on your Leather. I could stretch my Lether sheet more or less depending on the direction.
So my way to solve this: I left the last 2cm to the knob untouched, with enough Lether left . I put the Leather on the Lever as shown above and at last i cut the Leather and make the puncture and the 4 stitches.
Make shure the Leather is really tight and you will be able to get it under the rabbet easily.
