Hi all,
First post here but I have a 1990 R32 GTR with a small power steering leak coming from the high pressure hose leading out of the power steering pump. I had the PS fluid flushed and replaced earlier this year and this leak seems to have developed within the last few months. The car drives fine and doesn't make any strange noises but will leave a few drops on the floor after turning into a parking spot. I got under the car and identified where the leak is coming from as shown in the photo here (the dark streak on the left is the dribble of PS fluid from where the hose meets the metal fitting). 797251782_WeChatImage_20190909171832.thumb.jpg.3d667d5d508af8d269cd3077ee213182.jpgI've attached another image of the part and the leak area circled in red.
My question is, would it be possible to tighten the metal fitting to stop the leak and if so, how would I go about it? Second, I don't mind buying the whole high pressure PS assembly pictured and swapping it all out as a preventative measure (as I can't find the rubber hose/metal fitting alone), but would this be something that can be done just by getting under the car or would the engine/large components need to be removed first? Thanks for any insight you may have!
Edited by nouveau_poor
rewording
https://www.sau.com.au/forums/topic/478626-r32-gtr-power-steering-leak/
Thanks for the reply. I read somewhere else something about a crush washer deteriorating over time leading to a leak but that might not be applicable to the fitting in question. If the swap can be done without removing the engine or major parts I'll do it myself or ask my mechanic. In the meantime, has anyone had luck using power steering additives to stop small leaks like this?
Well I'll go ahead and order the assembly if the rubber hose can't be saved. Hopefully replacement isn't too difficult and labor costs aren't too high. I don't enjoy having to top off my PS fluid all the time. I'll try to keep the thread updated when I get around to installing.
You could just remove the assembly and take it to a hydraulic hose shop and they could put on a new bit of hose in a few minutes. Obviously you would discuss this with them in advance and show them the picture and book a time to walk it in....
But it would save you the arse raping that you'll probably have to endure to buy the whole thing.
  • Like 2
Hydraulic shop, Enzed, Pirtek...they will make it while you look on in amazement.  Take about 15 minutes....ie a hellava lot quicker than you when you have to remove and refit it, that will take you half a day and skun knuckles.
That's some good advice about the hydraulics shop, I'll keep it on my radar. It does sound a lot less painful to just fix the rubber itself. A local shop is selling the whole pipe for a tad less than from Nissan so I was thinking that replacing it all with OEM would be good for the long run. Is the rubber hose alone removed from where it meets the hard line by the first metal plate/bracket? If so, I'm surprised that Nissan doesn't sell the hose alone if the whole pipe can be disassembled like that.
The hose is crimped onto the hardpipe ends. It's non-trivial to remove and refit.....unless you're at a hydraulics place.
So an update as promised. I ended up going the full assembly route as i figure it's long-term insurance and I would have had to pay someone to remove the old assembly anyway and so the price difference between a repaired hose +install and a new OEM part + install was worth it to me. I took a peek under the car beforehand to see if I could remove and reinstall myself but could not for the life of me find a straightforward way to weave the bends and everything around the steering rack. Dropped it off at my usual shop for a day and got it back a bit ago. No leaks (as one would hope) and I don't think they had to remove neighboring bits to do it. Not sure what kind of witchcraft they used but it went in the same way the old one did. Ideally it should be good now for another 30 years right? Pictures of it snaking around below:
It goes behind around all this stuff
The switch/plug for the high pressure line
Here you can see the leak flowing down the hose before it turns into hard line again
3 pipes go into the power steering rack assembly. The one replaced is the center one.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
